10-25-2014, 01:09 PM | #1 |
Newbie Join Date: Oct 2014 Location: Geronimo
| Help with finding pinion gear for axle.
Hello everyone. I'm looking to try and a find a pinion gear for a wraith rear axle. I'm building a custom project and I need to wraith gears to match my losi front gears. The losi is running 43/11 and the closest I found for the wraith was 43/13. So my question is what other companies have gear options that fit the wraith axle? Or does anyone know of an 11 tooth pinion gear that works?
10-25-2014, 04:47 PM | #2 |
Rock Crawler Join Date: Jul 2008 Location: Pearland, TX
| Re: Help with finding pinion gear for axle.
Axial has HD under and over drive gear sets as an option. Check out rpp hobby.com and type in wraith gears and I bet they will come up.
10-25-2014, 04:54 PM | #3 |
RCC Addict Join Date: Aug 2013 Location: Missoula
The problem is, you can't just mix and match pinions and ring gears. The paired ratios have teeth that match up, the wrong pinion won't line up with the wrong ring gear.
10-25-2014, 05:15 PM | #4 |
I think I read somewhere that some hpi gears work as well? Any other models? Or has anyone heard of changing out losi scte gears to a different ratio?
10-25-2014, 05:28 PM | #5 |
Hpi gears work to build an open diff in place of the locker. Haven't seen any that take the place of the ring and pinion.
Help with finding pinion gear for axle. - Similar Threads | ||||
yota axle ring and pinion gear replacement alternatives? | cydog510 | RC4WD Trail Finder 2 | 10 | 05-14-2017 02:09 PM |
Help with finding correct spur and pinion | Andyking | Axial Wraith | 7 | 12-17-2013 01:10 PM |
axle pinion gear search | minimonster | General Crawlers | 1 | 08-06-2011 07:01 AM |
Finding the pitch on a pinion | mudhunter | General Crawlers | 2 | 04-16-2007 08:11 PM |
