10-30-2014, 03:35 PM | #1 |
Pebble Pounder Join Date: May 2013 Location: new zealand
| does the deadbolt body fit wraith???
hi im looking at buying a deadbolt to do a 1.9 wraith build and just would like to know if anyone knows if the body will fit a wraith??? ive seen talk of the falken body fitting so was guessing the deadbolt would be closesince it has the same cage etc buy te looks of it. I like the look if it the best out of the axial bodies because im not really a jeep person. im asking because I live other side of the world and we don't have any hobbies stores here etc so I have to order everything off the net |
10-30-2014, 04:11 PM | #2 |
Quarry Creeper Join Date: Aug 2013 Location: South Crawlolina
| Re: does the deadbolt body fit wraith???
I think it will. I'm not 100% sure, but the deadbolt body is available on the SCX10 G6 and those bodies fit the wraith which means the deadbolt body should fit the wraith too, if that makes sense. Axial's website says the Deadbolt body is compatible with the wraith.
10-30-2014, 04:19 PM | #3 |
that's what I was thinking so hopefully it fits when I order one
10-30-2014, 05:36 PM | #4 |
Pebble Pounder Join Date: Oct 2004 Location: Indianapolis
The Wraith cage is part of the chassis while the Deadbolt cage is bolted to the body. To get the body to fit on a Wraith you will either need to cut the top of the Wraith cage off to make it flat or cut out the interior on the Deadbolt body to let the Wraith cage come thru.
10-30-2014, 05:46 PM | #5 |
I understand that the cage is screwed to the body. I was asking about if anyone has actually sat it over the wraith cage
10-30-2014, 07:24 PM | #6 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
This is a pretty quick & nasty alignment job but scaling the 2 together, once the cockpit is cut clear of the deadbolt body it should drop over the Wraith chassis like the Poison Spider Jeep body does.
10-30-2014, 10:47 PM | #7 |
Rock Crawler Join Date: Apr 2006 Location: Hartland, MI
I cut a G6 body for a Wraith and it fits, so the Bolt body will do the same.
10-31-2014, 03:07 AM | #8 |
Thanks guys I think I will go ahead and buy this once im back onshore from work so I can get my next couple of projects started
does the deadbolt body fit wraith??? - Similar Threads | ||||
Is Spyder body direct fit to the kit Wraith? | bretkissick | Axial Wraith | 2 | 10-14-2013 02:46 PM |
Wraith body kit to fit a timberwolf tuber? | Tgreer | General Scale Talk | 0 | 07-20-2012 09:36 PM |
