12-07-2014, 02:43 AM | #1 |
RCC Addict Join Date: Feb 2012 Location: UK
| Q: Why are then no Steel axle casings?
Just wondered as non rotating weight is best and this would help in that area and be tougher than Aluminum. |
12-07-2014, 08:11 AM | #2 |
Pebble Pounder Join Date: Jun 2014 Location: South Ontario, Canuckistan
| Re: Q: Why are then no Steel axle casings?
I'm guessing that it would be too heavy, rust like crazy, and too difficult to machine.
12-07-2014, 08:19 AM | #3 |
I wouldn't mind the rust. Have to under-seal the axles like a 1:1. You maybe right about the weight. I have no idea how much they would weigh in comparison to what is currently available.
12-07-2014, 08:36 AM | #4 |
Rock Crawler Join Date: Jan 2010 Location: rockford
Gcm used to make steel axle housings. But good luck finding them.
12-07-2014, 09:27 AM | #5 |
Rock Crawler Join Date: Feb 2012 Location: Tennessee
I would say manufacturing cost is the biggest issue.
12-07-2014, 09:46 AM | #6 |
Yes, cost to manufacture is a big hurdle. It would take two to three times longer than milling out aluminum, hence two to three times the price.
12-07-2014, 02:40 PM | #7 |
Plus that is a lot of unsprung weight. While keeping rotating mass down is a good thing, you also want to be conscience of how much unsprung weight you have if you are looking for handling at any sort of speed.
12-08-2014, 01:31 AM | #8 |
That's interesting. If rotating mass and unsprung weight are not ideal where would the optimal place to weight be? I'd guess around the stock servo area. Thanks for the input folks. |
12-08-2014, 08:11 AM | #9 | |
| Re: Q: Why are then no Steel axle casings? Quote:
The number I had always heard before was 1 pound of unsprung weight made the suspension react as if you added 7 pounds of sprung weight. Now that was a scale of magnitude more appropriate for full size cars and I don't know if that linearly scales to 1:10 or if it's exponential. All just food for thought. You can find some interesting reading on the topic if you are truely interested. | |
12-08-2014, 11:05 AM | #10 |
Moderator Join Date: Jan 2004 Location: chicago
i got steel gcm ar60 axles on my scaleready wraith. i also have a set of their steel scx axles on my c2 comp scaler, and i very much like the added weight down low for most things. i do however see instances where a light weight rig will basically walk up something i have to try a little harder at, but in other instances the heavy weight down low helps. biggest reason i like the steel gcm axles is how dam easy they are to open up, and they are virtually indestructable. |
12-08-2014, 11:13 AM | #11 |
I would want them to be able to weld shock and link tabs on in any place I wanted! I wouldn't mind just steel tubes for my Currie axles or something.
