01-12-2015, 12:20 PM | #1 |
Pebble Pounder Join Date: Jan 2014 Location: NB Canada
| MMP help
Hi all, I did some quick googling at lunch but couldn't figure out what I needed so I'm asking here since this is the place I usually find the most usefull information. I'm setting up a new powertrain for my wrait on the bench. I'm adding the AX2 2 speed tranny, MMP ESC, and I've chosen a leopard sensored 2900 kV motor. After getting a shift servo fitted and working I started with the motor and at first it seemed to start to move slowly fine at low throttle then surge. So, after some reading I see some firmware upgrades to the MMP was supposed to fix that. I hooked up the castle link and updated the firmware thinking, ok, fixed! Alas, now it seems to do nothing for the first ~10-15% of throttle then blamo, turns on quick. Has anyone dealt with this? I'm fairly new to the MMP/Castle link stuff but I think I could figure out how to follow instructions if anyone can point me in a sensible direction. Any advice or thoughts ar greatly appreciated. |
01-12-2015, 01:15 PM | #2 |
| Re: MMP help
Is it set to smart-sense or sensored only?
01-12-2015, 04:51 PM | #3 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: MMP help
You may also need to recalibrate the transmitter to the ESC. Sometimes firmware updates on the ESC end up needing recalibrating.
01-12-2015, 06:21 PM | #4 |
| Re: MMP help |
01-12-2015, 07:33 PM | #5 |
| Re: MMP help
So I have a bit of an update. I decided that I'd try it without the sensor wire and it worked exactly the same. Plugged the sensor wire back in and now it just vibrates back and forth, doesn't actually turn :S. Man I am frustrated. :(
01-12-2015, 07:50 PM | #6 |
| Re: MMP help For the vibration, switch A & C wires. Sensor wire could've been not fully seated and been running in sensorless mode.
01-12-2015, 10:22 PM | #7 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| Re: MMP help
You might try a different sensor wire also...they aren't 100% reliable either
01-13-2015, 09:07 AM | #8 |
| Re: MMP help hunh, this is my first sensored brushless, so now that it is sensored the A/B/C wires make a difference? With unsensored brushless I know that switching any 2 changes direction... is this different or more involved now with sensored?
01-13-2015, 09:14 AM | #9 |
| Re: MMP help
The sensor can sometimes fight the motor direction, if it's incorrect. One manufacturers ABC can be different than another, I've found.
01-13-2015, 10:40 AM | #10 |
Pebble Pounder Join Date: Feb 2007 Location: Monrovia
| Re: MMP help
When running sensored it absolutely makes a difference which wires are which. You have to hook up a-a b-b and c-c.
01-13-2015, 02:59 PM | #11 | |
| Re: MMP help Quote:
I still have a slight issue with it not starting off slow enough though, seems to get to about 10% throttle before it kicks in and won't just go slow, although this is still on the bench so I have no idea how slow it might be in the rig ;) Thank you so much for the help guys! I can't wait to get this 4 pole sensored bruhsless 2 speed combo in the otherwise stock wraith! | |
01-14-2015, 09:06 AM | #12 |
Newbie Join Date: Nov 2014 Location: Nova Scotia
| Re: MMP help
Check your throttle curve when its hooked up to castle link. If the curve is set to low in the beginning you wont' get any throttle response until the trigger is pushed so far. Also check your transceiver and see what settings might be there for throttle exponential if it has it.
MMP help - Similar Threads | ||||
CC mmp vs mmp sct edition? | mudd_slinger | Electronics | 5 | 06-05-2013 01:18 PM |
