01-13-2015, 09:09 PM | #1 |
I joined the Band! Join Date: Sep 2012 Location: Lake Forest
| Vanquish housing question
Looking for feedback on the vanquish axle housing. I read somewhere that the threads strip out. That's the only thing holding me back from the purchase. Anyone running them with success? I'm running a brushless system and drive my trucks pretty hard...
01-13-2015, 09:20 PM | #2 |
| Re: Vanquish housing question
I have been using them for awhile now, brushless ROC412 3100kv powered, nothing stripped out or damaged yet...
01-13-2015, 09:35 PM | #3 |
That's what I like to hear. I have strc c-hubs,knuckles. Any input on the fit with these? Unfortunately the vp ones were out of stock when I purchased...
01-13-2015, 09:39 PM | #4 |
strc c-hubs had a loose fit, i bought VP stage 1 kit....
01-13-2015, 09:48 PM | #5 |
Quarry Creeper Join Date: Jan 2011 Location: 808 via Reno, Nv.
| Re: Vanquish housing question I run them with my STRC C-hubs, knuckles and lockouts. I still have issues with the screws backing out even with blue locktite. Haven't had them strip out though ( knock on wood ). I just check and snug the screws back up after each run. I love my VP axle housings, I also purchased a pair of steel diff cover skids to protect them too. |
01-13-2015, 10:16 PM | #6 |
I know red locktite is a no no. But it's not that often I remove those parts. A heat gun would loosen the red up pretty quick. I can never find the vp stage one kit in stock..
01-13-2015, 10:59 PM | #7 |
Ordered the vp housings, vp scale c-hubs knuckles and dmg skid plates..Hope I'm happy |
01-14-2015, 01:19 AM | #8 |
| Re: Vanquish housing question You will be, the quality and craftsmanship is superb. Those are the same skids I have on mine too. well worth the money and protection. Getting them scratched up is gonna be the hardest part, but that's what they are for. What color housing did you get? Mine is silver with silver STRC products.
01-14-2015, 04:06 AM | #9 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
Ive had mine for a while now, nothing has stripped out. Only issue was screws loosening up on front chubs due to the tiny bit of play, the new scale hubs should fix that, just installed them too and they seem great! I think they would stay with no screws!
01-14-2015, 08:09 AM | #10 |
I got black axle housing with black diff cover. I already had grey trusses and shock mounts so I ordered grey scale c-hubs and knuckles and a set of mips. It's hilarious because I was going to keep this rig semi-stock. Now it's my favorite and going full out lol. Thanks for the feedback!
01-14-2015, 02:30 PM | #11 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
I have had mine for quite a while now. There's not a lot of metal (depth) for the screws to bite into and mine have gotten fairly loose. I ended up inserting beef tubes into the front VQ axle and now there's lot's of threads for the bolts and they are steel, not soft aluminum. The scale VQ CHubs would be better because they clamp down in addition to the upper and lower bolts. I recently rotated the rear VQ lockouts 180 degrees, drilled and tapped new holes because they were not staying tight with the original holes....plus, now the two bolts that were previously on the bottom of the axles will not longer scrape the rocks. I'm quite anal and perform lots of maintenance on my rigs which means these bolts get removed fairly regularly, which is likely the cause of the holes not staying tight. I use blue Loctite every time. Would I buy these axles again....absolutely. |
01-14-2015, 04:31 PM | #12 | |
Rock Crawler Join Date: Mar 2013 Location: columbus
| Re: Vanquish housing question Quote:
I also drilled and tapped my rear for 2 more screws. The lockouts were forever coming loos even with red loctit. My lockouts have 4 screws in them and have not backed off yet Last edited by greengoblin; 01-14-2015 at 09:33 PM. | |
01-14-2015, 04:40 PM | #13 |
Newbie Join Date: Jun 2014 Location: Fort McMurray, Alberta
bilinvic, were the lockouts coming loose with the beef tubes installed or was that prior to beef tubes?
01-14-2015, 05:04 PM | #14 |
My rears dont come loose but i have a one piece 5mm ti axle going straigh through the locker and 2 extra bearings, maybe that helps!
01-14-2015, 05:25 PM | #15 |
| Re: Vanquish housing question So many great ideas and proven methods. This is why I am addicted to these forums. Thank you everyone for sharing your experience, ideas, and methods. The hardest part now is deciding which route to take to secure these hardwares in place. I'm sure having a heavy 10# rig doesn't help either. |
01-14-2015, 05:45 PM | #16 | ||
01-14-2015, 06:42 PM | #17 |
I'll report back after awhile running them. Great info. Thanks |
01-14-2015, 07:13 PM | #18 |
| Re: Vanquish housing question Weight wise sounds like your right up there with me , with the exception of the fact that I have 8oz weights per wheel up front and 4oz per wheel out back also mounted on CAC E-Z lock wheels and full droop suspension with G-Transition shocks, 0 up travel but a a lot of down travel. She sticks to the rocks like glue but hill climbs are horrible, I'm guessing the weight is a major factor. All it wants to do is sink into the dirt. LOL.....
01-14-2015, 07:24 PM | #19 |
Sounds like your machine needs to go on a bit of a diet! I don't use weighted wheels and she climbs awesome.
Vanquish housing question - Similar Threads | ||||
Vanquish for SCX10, Currie or Vanquish housing? | DrDiff952 | Axial SCX-10 | 8 | 12-06-2014 01:13 PM |
Vanquish currie housing?? | krazikev | Axial SCX-10 | 4 | 03-29-2014 10:01 PM |
vanquish alum axle housing | Hoser1869 | Axial SCX-10 | 0 | 01-31-2014 10:26 PM |
vanquish tranny housing mirror | uclabruins89 | Axial SCX-10 | 2 | 06-21-2013 02:03 AM |
