Thread: Looking for CMS, 1.9, panhard ideas....
Old 01-29-2015, 12:16 PM   #1
Default Looking for CMS, 1.9, panhard ideas....
A while back I bought a Level 3 cms on ebay. What I didn't realize then is that I bought one that does not include a panhard mount. Any ideas what I could do about the frame side panhard mount? Does anybody sell one? I thought I saw one a while back but can't find it now.
KBR97 is offline   Reply With Quote
Old 01-29-2015, 01:06 PM   #2
Default Re: Looking for CMS, 1.9, panhard ideas....
you will need a whole new servo mount. I would get the vanquish one.
Vanquish Products Wraith Chassis mounted Servo KIT
Vanquish Products Wraith Panhard KIT
You should be able to sell the axle mount quite easily.
fr8cture is offline   Reply With Quote
Old 01-29-2015, 01:24 PM   #3
That vanquish one is pretty much the same as what I have pictured above. I don't see a panhard mount on it.
Edit...nevermind. Didn't realize the second link had it.
Old 01-29-2015, 02:07 PM   #4
I'm actually thinking about making one after looking at the difference between the level3 with mount and without mount.
I drew up a template that I can use to cut out a small piece of aluminum or even steel. I can shorten the spacer on the cms a little and mount it behind the front plate.
Something like this...
Old 01-29-2015, 02:44 PM   #5
That should work!
TwistedMetal is offline   Reply With Quote
Old 01-29-2015, 02:51 PM   #6
I just cut out a piece with some super thin aluminum. Obviously I'll use something with more beef.
Old 01-30-2015, 05:04 PM   #7
Natedog's Avatar
I'd sell the Level3 junk.
Then stand the servo up like the SCX kits from RCBros and RC3WD do, making sure that servo is mounted so that servo arm points forward (like the steering knuckle arms) this should get the best steering. Make your own panhard mount.
Old 01-30-2015, 08:54 PM   #8
I haven't seen a kit that stands it up like that? Or would I have to make something?
Old 01-30-2015, 09:30 PM   #9
there isn't one. I personally like the sideways mount but I prefer the rc4wd or vp mount.
Old 01-30-2015, 09:54 PM   #10
For me over half the fun is making my own parts. I did a cms and panhard on my scx10. Turned out great with no bump steer.
Old 01-31-2015, 05:59 AM   #11
Try this:
Servo mounted vertically to chassis in a Wraith
new2rocks is offline   Reply With Quote
Looking for CMS, 1.9, panhard ideas.... - Similar Threads
Cms and panhard for G6 nerby149 Axial SCX-10 16 01-25-2015 07:44 AM
rc4wd CMS/Panhard BoardN88 Axial Wraith 6 04-26-2012 01:47 AM
vp cms/panhard ax10tn Axial Wraith 22 02-07-2012 05:38 AM
