Wraith NOT RESPONDING Hey guys, So i used my Wraith today. All electronics are stock except my servo is a Savox SW-0231 and i changed the gearing to 16/87. I also changed the battery connection to a deans and run a 2s lipo battery. After a while my motor got very very hot and the car stopped working. I let it cool down and turned it on an hour later. All lights turn on, but when i turn on the remote controller and try to turn the wheels or give it power, nothing happens at all. Just the lights flicker a bit. Do i need a new motor or esc? |
Re: Wraith NOT RESPONDING Tekin baby tekin all the way. RS gen2 esc with a roc 412 motor |
Re: Wraith NOT RESPONDING Quote:
Re: Wraith NOT RESPONDING Call me crazy but its rhe servo. Try to check the servo. I had something like that happen to me with the stock servo. |
Re: Wraith NOT RESPONDING Yes you can try that. And if moves too slow is a way to know. |
Re: Wraith NOT RESPONDING If you're not running an external bec with that servo then your ESC may be toast and the esc may have killed your motor as well. http://www.rccrawler.com/forum/chit-...ernal-bec.html |
Re: Wraith NOT RESPONDING Do you have any spare motors, esc's or servos? Process of elimination. |
Re: Wraith NOT RESPONDING Disconnect your servo, your motor should run without a servo attached, start with a cheap brushed motor, if it still doesn't run your issue is the ESC, Tekin or Castle ESC's are top of the line and will last if your gearing is properly set up. |
THANKS GUYS I SOLVED IT. I need a BEC |
Re: Wraith NOT RESPONDING Servos can draw a lot of juice. When mine died it caused the rig to stop completely even though the have a bec; think I'll wire it directly next time rather than through the rx. |
Re: Wraith NOT RESPONDING My servo didn't die right? It's still works? Once I hook up a BEC will my servo start working again? |
Re: Wraith NOT RESPONDING No guarantees until you try. I had one of those servos fail after not much use. Caused lots of glitching. :( |
Re: Wraith NOT RESPONDING I test fit a bec on my spawn..everything worked then.. I didn't get a chance to install the bec today...I needed to make a run to the LHS..then i pulled the wraith out for a quick run at the park..No response at all...get home...try binding it....hooked up a different transmitter and reciver..this one worked..its an AX3 tx and AE5 esc..not much help info out there for these,.Ideas? |
Re: Wraith NOT RESPONDING if it worked with a different transmitter isn't it obvious what the issue is? |
Re: Wraith NOT RESPONDING Transmitter broken and not even 5 packs run through it yet..jeez.. |
Re: Wraith NOT RESPONDING Im here for help....Either tx is gone or reciver .. how to know which one is bad? What to do? Anyone have tx rx issue fixes? |
Re: Wraith NOT RESPONDING Try a new rx and if it doesn't work it's the tx |
