02-15-2015, 11:43 AM | #1 |
Newbie Join Date: Feb 2015 Location: duluth
| just random cool poison spyder wraith stuff
Hey y'all just wanted to start up a new wraith thread cause theyre so cool haha. But I have a lot of questions about my wraith that im hoping people can answer. Yes I have looked around on here and yes I have seen all of harleys videos on it. A few ?s I have are: 1. What gear ratio would you recommend on it? Right now its stock but im thinking to drop to a 10 tooth pinion. 2. I have a 27t in it right now, just the regular axial motor. Would I get better runtimes and/or power if I went to something like a 35t? Or is it the battery alone that controls the runtime? I have a few more but ill wait to see if I cant figure them out myself
02-15-2015, 12:03 PM | #2 |
Rock Stacker Join Date: Apr 2014 Location: Altoona,Florida
| Re: just random cool poison spyder wraith stuff
Im running 10t pinion with a 54t spur 32p on axial 27t motor i get great runtimes on 2s lipo 5000mah. The weight of my ps wraith is about 5 lbs 6lbs when the tires are covered in mud still goes strong Ren |
02-15-2015, 03:21 PM | #3 |
Nice! Thanks! Im thinking about leaving the crappy 48p gears and switching to a 10t pinion, so it will hopefully crawl 2x as good. Gear ratio in trans would change from 4:1 to 8:1 so I dont know how itll crawl but im hopin itll be better
02-15-2015, 06:51 PM | #4 |
Pebble Pounder Join Date: Jul 2013 Location: Candler
I'm not so sure that you will get any gear mesh with a 10t pinion and 80t spur. I don't think you'll be able to slide the motor over close enough.
02-15-2015, 07:09 PM | #5 |
Quarry Creeper Join Date: Jul 2014 Location: North Florida.
And just going from a 20t to a 10t alone wont double your gear ratio..
02-15-2015, 07:34 PM | #6 | |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: just random cool poison spyder wraith stuff Quote:
80/20 = 4.00:1 80/10 = 8.00:1 But that's not the "in trans" ratio that's just the spur and pinion ratio. The transmission is fixed at 2.60:1, and final drive ratio would be just under 60.8:1 with the stock (2.923:1) axle gears. Last edited by Eric0424; 02-18-2015 at 09:54 AM. | |
02-16-2015, 08:25 PM | #7 |
Hmm... so should I go with a bigger spur too then? Also what would you guys reccomend for a long lasting powerful battery in a 2s size? Dont really want to do 3s just yet.
02-18-2015, 06:15 AM | #8 |
Im going with a robinson 13t pinion
just random cool poison spyder wraith stuff - Similar Threads | ||||
Poison Spyder Wraith | godofcable | Axial Wraith | 4 | 12-10-2013 01:41 PM |
poison spyder wraith | Frakke | Videos! | 7 | 09-22-2013 07:56 AM |
