03-08-2015, 04:12 AM | #1 |
Newbie Join Date: Jan 2005 Location: Ravenna
| Currie centered axle issue |
03-08-2015, 07:00 AM | #2 |
Quarry Creeper Join Date: Jun 2011 Location: butler pa
| Re: Currie centered axle issue
Is your axle tube in all the way? give a light tap on the end of the axle, i have a centered currie on mine with vp locker no problems. What locker are you running?
03-08-2015, 08:14 AM | #3 |
in those pics they were not attached, but even after being fully built its the same. i am running lurc fi lockers. everything fits great except the hexes, that is as far on as they go.
03-08-2015, 10:30 AM | #4 |
I joined the Band! Join Date: Dec 2014 Location: Earth
Looks like the shoulder needs about .060-.080" (1.5-2.0mm) shaved off, just a rough estimate based on the pictures. That's if you're sure it's not the pin, I'm guessing you've already checked the pin fit in the hex.
03-08-2015, 11:13 AM | #5 |
Pebble Pounder Join Date: Jan 2011 Location: london,England
my pins were to big so shaved a bit of. take the pins out and hex of and see if pin fit.
03-08-2015, 11:23 AM | #6 |
the pins fit in the hex no problem, they were already used on the truck. like eric0424 mentioned, i think it the axle.
03-08-2015, 03:29 PM | #7 |
Quarry Creeper Join Date: Dec 2010 Location: Anaheim
just buy the vp clamping hexes they will slide right over since they have the lil pinch slot cut in them. My son and I both have the centered rear and use the vp hexes. both fit perfect. Its not ideal to have to get another piece but might be best option. My axial hexes were just old and at the end of their time so bought the vp hexes cause I was already buying other stuff Don't know if they have a issue with other hexes. would be interesting to find out incase I need a spare on the trail.
03-08-2015, 03:32 PM | #8 |
RCC Addict Join Date: Dec 2007 Location: London
How is this a Vanquish Currie Issue? Surely its an Axle Issue? Or am I missing something. |
03-08-2015, 03:48 PM | #9 |
uh the axle for the centered currie is made by vp for that rear end and comes with the currie kit. not a big issue to me just want to know if other brand hexes don't fit than I will buy me a extra set of vp hexes for spare so I don't rely on a buddy lending me a hex that might not fit. its only a couple bucks for a set of spares just wondering. |
03-08-2015, 05:18 PM | #10 |
| Re: Currie centered axle issue |
03-08-2015, 10:45 PM | #11 |
thanks for all the help. i wasnt sure if the vp hexes would work. will order them today.
03-31-2015, 03:01 PM | #12 |
I just bought some more hexes and they have the same issue. as you are having contact VP they are gonna work with me but they need to know other people are having the same issue. They have the same problem with the stock hexes and the VP hexes. |
03-31-2015, 03:10 PM | #13 | |
| Re: Currie centered axle issue Quote:
VP is awesome they will see the difference and fix it. I have some hexes that were machined a lil different too so I actually have a set of hexes that I can get to work with the rear VP shafts. Those are older vp hexes maybe they changed something in the new ones. I can get everything to fit correctly and get back to crawling if I run my older hexes on the centered shafts and my newer hexes on the vvd's. Something has to have changed somewhere. Last edited by mrhobby100; 03-31-2015 at 08:23 PM. | |
04-07-2015, 06:32 AM | #14 |
Quarry Creeper Join Date: Sep 2014 Location: UK
I've also noticed this too after my last day out with my Yeti. I beat on it pretty hard and the hex started to wobble as they chewed the pin slot up because they would only go half way in.
04-07-2015, 12:33 PM | #15 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
Is there a step inside the hex that did not fit- meaning, did the hex bottom out on the shoulder of the axle (just inside of the threads) keeping it from seating on the pin? I have had to drill hexes a little in the past (non currie) to get them to fit cvd's - could this be the issue? |
04-08-2015, 08:17 AM | #16 |
Yes that is the issue sort of. The older version of the vp hex was designed around the older scx10 that used 10mm hex pins. Axial has since changed to am 11mm hex pin so vp updated their design. The cnc program got messed up somewhere by accident and the machine was NOT drilling the center lip deep enough. Rob looked over everything and is gonna fix it. Also the pin location on the centered axles needs to be moved out about 1thousandth amd rob also saw that. They fixed the program and told me to send back my hex's and rear centered shafts and they are gonna get everything straightened out. Anybody who has a vp hex issue or centered shaft issue contact VP they will take care of you.
Currie centered axle issue - Similar Threads | ||||
vanquish centered axle shafts to GCM centered housing compatibility | npcaldwell | Axial Yeti | 7 | 01-31-2015 12:47 PM |
Rc4wd centered rear axle | otis683 | Axial Wraith | 2 | 09-15-2013 09:40 AM |
Centered pumpkin wraith axle? | driftdreamer06 | General Scale Talk | 9 | 10-07-2012 11:22 AM |
