05-02-2015, 05:58 AM | #1 |
Rock Crawler Join Date: Aug 2008 Location: Portland, Maine
| Which wheels will fit over blue monkey wheel weights?
Just got some blue monkey wheel weights that are made to fit the stock axial knuckles and they don't fit into my motorworks wheels. Anyone have recommendations of a wheel the will fit? These weights do fit the stock wraith wheels but I am looking for something aluminum and with a beadlock.
05-03-2015, 09:19 AM | #2 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: Which wheels will fit over blue monkey wheel weights?
What diameter are the knuckle weights? them we could measure some wheels to know if they fit |
05-03-2015, 09:27 AM | #3 |
Rock Crawler Join Date: Nov 2011 Location: Asheville
Not sure on the wraith but I had some for the scx10 high steer knuckles on my berg and I know that VP slw's wouldn't fit I ended up grinding them down till they fit
05-04-2015, 01:57 AM | #4 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
I'm running these weights with 2.2 Vanquish OMF. Mayhem does NOT fit over, hubs are to large, so my guess is that it has to be SLW. They clam the 475-hub to give enough space for two ekstra rings, but I had to use 600 hubs for this.
05-04-2015, 07:26 AM | #5 |
| Re: Which wheels will fit over blue monkey wheel weights? So you are using the blue monkey weights that are a full circle design made to fit the stock axial knuckles? Just want to be specific and sure before I buy any vanquish products. Also what rings are you using on your OMFs? Thanks
05-04-2015, 12:27 PM | #6 |
It's the regukar VP hubs and knuckles, with the knuckle weights made for them. 600 hubs up front on 2.2 OMF gives enough clearance two run two extra rings of weight.
