07-21-2015, 08:59 PM | #1 |
Newbie Join Date: Jul 2015 Location: Hagerstown
| axle shafts
hey guys. i was wondering what axle shafts would fit in the rear end. will vanquish axle shafts work?
07-21-2015, 09:53 PM | #2 |
Moderator Join Date: Jan 2004 Location: chicago
| Re: axle shafts
i assume you have a stock wraith? stock ar60 ocp axle on a wraith has an offset diff (ocp means offset center pumkin iirc) so it has different axleshaft lengths per side, i dunno if vp makes a rear axleshaft set (non steering) for an offset differential, but if you are talking about the vp axleshafts for the centered differential than no, they will not fit. |
07-22-2015, 06:24 PM | #3 |
| Re: axle shafts
Nope. My friend told me that the steering ones would work on rear. Yes I know it will if I was doing 4 wheel steer. But yes shaft and housing wise it's stock. I have f1 spools with vp front shafts, vp steering, vp knuckles, vp c hbs, vp lockouts. Alot more vp stuff. Not really stock anymore lol.
07-24-2015, 08:47 PM | #4 |
Rock Crawler Join Date: Dec 2013 Location: Tuxedo NY
| Re: axle shafts
Does anyone make a wraith rear shaft? Creeper bob?
07-25-2015, 01:23 PM | #5 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
| Re: axle shafts
Pretty sure super shafty does. I know they do upgraded shafts for the scx10...
07-25-2015, 02:27 PM | #6 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: axle shafts
Yes front shaft will fit in rear but you would need chubs and knuckles and tie rod to hold them straight but totally pointless to do that if your not going to run 4ws. Plus extra money too. Why cant you just get some replacement rears? (Assuming you broke a rear shaft and thats why you are asking).
07-25-2015, 02:35 PM | #7 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: axle shafts
I thought there were upgraded, stock length rear axles for the Wraith, but everything I'm finding are stock Wraith rear axles unless you want to convert to rear steer with universals or CVA's. Super Shafty's site is down right now for maintenance, so I couldn't check with them yet. |
07-26-2015, 08:17 AM | #8 |
| Re: axle shafts
Yeh I'd like to do 4ws. But haven't gone to that jump yet lol. Still getting used to the wraith wheeling wise.
07-26-2015, 09:58 AM | #9 |
| Re: axle shafts
I'm just about finished with the rear steer on mine, waiting on the right servo horn to get here so I can officially call it "done".
