10-24-2015, 01:41 PM | #1 |
Quarry Creeper Join Date: Aug 2014 Location: Indy
| are VP VVD's worth it?
I'm running the axial unis now and have an extra set. But they don't engage into my vp lockers far enough to lock them with the set screws. So do I get VVD's or different lockers? If the VVD's are a lot tougher than the axial units then I'm down with it. If not I can get a pair of spools cheaper.
10-24-2015, 02:08 PM | #2 |
Pebble Pounder Join Date: Sep 2015 Location: Australia
| Re: are VP VVD's worth it?
From the research I've done, the axial universals are just as if not more reliable than the VVD's. I'd say go extra spools. I noticed Die-Laughing (rick from Gripfab)had some Gripfab v2s for an awesome price. I'm waiting on some v3 ARBs that I picked up off him about a week ago that will get installed. Sent from my iPad using Tapatalk |
10-24-2015, 04:57 PM | #3 |
Another option is take the set screws out of the VP locker and run it that way. That way you can use the $$$ on another hop up. It all comes down to how OCD your are about the slop.
10-24-2015, 05:27 PM | #4 |
| Re: are VP VVD's worth it? I dont like the slop. When crawling I get this rig left right left thing out of the front tires and I don't like it at all.
10-24-2015, 05:41 PM | #5 |
| Re: are VP VVD's worth it? |
10-24-2015, 11:49 PM | #6 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
I just got done installing and testing new VP VVDs and HH spool and I'm pretty happy with this setup. There's no more slop but the turn radius is not quite as tight as it was with the universals. While I had everything apart I mocked up the HH spool with the Axial universals and it's mostly slop-free too. I think this would be the way to go if you have a good set of universals. Mine are pretty worn and have a fair amount of play in the U-joint itself plus I just forked out for the VVDs so I gotta use 'em.
10-25-2015, 12:26 AM | #7 |
Newbie Join Date: Aug 2015 Location: Littleton
I run the UNIs and HH spools and love em. This has been a very reliable setup with very little to no slop. It's time to replace my rears soon, not sure which way I'll go on those. I definitely want to go with a set that's an upgrade to the OEMs. I haven't had any issues with the Axial shafts that's just how I roll. |
10-25-2015, 01:11 AM | #8 |
Do yourself a favour and contact rick from Grip Fab. His spools are back in production but also has some old stock v2 for $23 a piece! You won't find a bad word about these lockers, he'll that's the reason I sourced them from rick and got them sent down under. You think I'd waste 10-15 dollars on a better or worse locker, hell no. I buy the best when I'm paying for postage from the states Sent from my iPad using Tapatalk |
10-25-2015, 06:29 AM | #9 |
Rock Crawler Join Date: Nov 2014 Location: Grimcity, On
The only problem I see with axial cvds, is that the pin and carrier at the stub, develop a lot of play. I believe that's why Gunnar makes no slop pins. Sent from my Nexus 5 using Tapatalk |
10-25-2015, 02:10 PM | #10 |
VVDs are much stronger. Stronger material and more of it everywhere. Much less slop than axial unis and rebuildable if you need to. They are a perfect match for the Vanquish lockers as well. You do get a bit less steering angle than axial unis. That's the only drawback I've seen but to be honest, didn't really notice a difference on the trail.
10-25-2015, 03:30 PM | #11 |
I decided to go with lockers. To many post about the vvd's breaking. Plus I have the scale knuckles with the 48 degree stops. Might as well make use of them.
10-25-2015, 04:36 PM | #12 |
Where are all the VVD breakage posts? VP VVDs or just that style in general? All I ever see is dog bone and axial Unis and CVDs breaking. Edit: I just read through Maslin's build thread and even when breaking a housing, the axial uni still held. I would consider his brand of durability testing to be pretty thorough and much more demanding than anything I've seen. I'd say if unis are lasting in his rig they're probably a sound choice. I will say if you had VP VVDs laying next to Axial unis and got to hold them and install and test them, you'd more than likely go with VVDs. Every part of them is better built with tighter tolerances and all but devoid of any slop. Last edited by SCREAMER; 10-25-2015 at 05:41 PM. |
10-26-2015, 07:02 PM | #13 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
From what I have read when both brands of shafts were used within the steering angle they were designed for the vvds are stronger. The problem is the vvd does not have as much steering throw as the universal and many people broke the vvds due to not setting EPA or having a hard stop to limit travel. As far as lockers go I love the idea of a set screw clamping style but the screws next to the ring gear don't have enough engagement against the surface of the tang and they can be hard to get set up correctly. |
10-26-2015, 07:54 PM | #14 |
I ran the Axial Uni's in my Wraith with an FI spool and liked the combo a lot. Great turning radius and though i was only running a HH 13T brushed motor they got hammered pretty good and held up just fine. I installed the VP VVD 5mm in my 15lb 1/6 scale with a GF ARB and will not run anything else in the future. Zero i mean Zero slop and more turning radius than my Wraith at 125 EPA. I often stuff the tires and get close to stalling the servo due it being harder to find the right line in such a long and heavy rig but i have no problems powering out if need be. I know the VVD's won't breaking anytime soon. I would be real hesitant to use Axial Uni's in this rig. |
10-26-2015, 09:38 PM | #15 |
What I find funny is VP built scale hubs with a steering stop. But the stop is farther than their own axles will support. So the designed and built a set that must use axial unis to take advantage of the steering stop. Their website stats the stop is set at 48 degrees and the VVD's max is 45. Lol wtf vp?
10-26-2015, 09:58 PM | #16 | ||
Quarry Creeper Join Date: May 2011 Location: Battle Ground WA
| Re: are VP VVD's worth it? Quote:
Regardless, the page for the scale knuckles says Quote:
10-26-2015, 10:05 PM | #17 | |
RCC Addict Join Date: Oct 2012 Location: Norcal
This was done by the Gladiator, LOL! I favor VP also but the uni's do turn a bit tighter. Snapping a VP stub shaft at the threads was probably a fluke.I keep a set of both in the tool box. | |
are VP VVD's worth it? - Similar Threads | ||||
New Vanquish VVD's | CKRC Hobbies | CKRC Hobbies | 0 | 11-04-2014 02:28 PM |
Vanquish VVD's | sharkbait | Axial Wraith | 2 | 07-26-2012 09:25 AM |
