02-01-2016, 04:38 AM | #1 |
Pebble Pounder Join Date: Jan 2014 Location: NB Canada
| Rock Lights
Hey all, just curious what people are doing for rock lights on their wraith. I'm a bit of a DIYer but also love a clean/scale/factory look.. Lets see what you've creative folks have come up with! |
02-01-2016, 05:35 AM | #2 |
Rock Crawler Join Date: Nov 2013 Location: In the country
| Re: Rock Lights
Autozone $12 for strip lights. I hear. Going to get some myself. J.A.W - just another wraith & a Bomber! |
02-01-2016, 08:44 AM | #3 |
Rock Stacker Join Date: Jan 2016 Location: US
| Re: Rock Lights These are a couple of examples I have used. The Wraith has individual amber LEDS in each corner while the SCX10 has white strip lights mounted to the inside of the body facing down. Both work great. Have about $3 in each setup. Sent from my SAMSUNG-SGH-I337 using Tapatalk |
02-01-2016, 10:14 AM | #4 |
Rock Stacker Join Date: Sep 2015 Location: Brunswick Hills
| Re: Rock Lights
How are you wiring the lights ? Are they prewired or are you putting the strings together yourself ? At only 3 bucks please show us how you did it. Are the LEDs available in different colors ? Where did you get them ? Sorry maybe too many questions but I would like to light up my rigs on the cheap. Have done a few with Axial lights but they are not that cheap.
02-01-2016, 10:55 AM | #5 |
| Re: Rock Lights
The lights for both rigs came from my LHS and I wired them straight off the battery lead going to the esc. I use a toggle switch on the truck to turn the lights on and off. The white lights on the SCX10 are strip lights that come on a roll and are waterproof with an adhesive back. You just cut them to length and solder on the wires. The wires for all lights on both trucks are ran back to a box on the frame that also houses the switch. The Wraith has ordinary LEDS. I found some one hole wire clamps that are the correct size to clamp onto the LED and attached them to existing screw locations on the bottom of the cage. I will try to get some close up pics of both setups tonight. And yes, both styles of lights can be found in several different colors Sent from my SAMSUNG-SGH-I337 using Tapatalk |
02-01-2016, 10:55 AM | #6 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
| Re: Rock Lights
I also used the cheap strip lights and a remote from Amazon, just search for LED strip lights. I stuck a 3-LED strip to the interior under each seat and to the underside of the hood, roughly above each wheel. Soldered on the leads and run them direct to 3s battery. There are dozens of choices - varying colors, remote dimmable, waterproof, etc. Check the voltage before you buy, most are 12v and can be run direct from 3s. Just stay away from the junk strip connectors they sell and solder them. I'll try to remember to post some pics when I get home tonight. |
02-01-2016, 12:14 PM | #7 |
| Re: Rock Lights
Close up pics of the set up would be greatly appreciated . Thanks !
02-01-2016, 12:32 PM | #8 |
Quarry Creeper Join Date: Dec 2012 Location: Remember, wherever you go. There you are.
| Re: Rock Lights |
02-01-2016, 10:18 PM | #9 |
| Re: Rock Lights
Here's my setup. All strip lights are wired in series with connections soldered and covered in hot glue. Under the hood Under the seats with one LED angled to the rear With main lights at lowest setting Rock lights only |
02-02-2016, 07:20 AM | #10 |
| Re: Rock Lights Here are a couple pics of how I mounted my rock lights. The foil tape on the SCX10 body is dual purpose. It helps reflect the light and keeps the body from glowing. Sent from my SAMSUNG-SGH-I337 using Tapatalk |
Rock Lights - Similar Threads | ||||
Rock Lights | (redbeard) | Axial SCX-10 | 31 | 04-04-2015 12:47 PM |
Rock Lights | AG74683 | Axial SCX-10 | 6 | 09-27-2011 11:24 PM |
Rock lights anyone? | m4rK | Traxxas Crawlers | 6 | 09-07-2011 06:07 PM |
Rock lights! | 16hp | Axial SCX-10 | 6 | 07-05-2011 10:07 PM |
tell me what think of my lights and rock rings | Flex | Tamiya TLT Crawlers | 24 | 01-20-2006 06:53 PM |
