Thread: Robison gen3 slipper
Old 02-23-2016, 06:34 PM   #1
Default Robison gen3 slipper
Waist of money or decent product?
Being a newb, I bought one used without searching beforehand. I noticed right away after receiving it that my top shaft was not going to work with it. I figured out that I either needed an older shaft that uses a pin for the slipper/spur or just upgrade to the Supershafty version. My top shaft is slotted...
Having taken a decade off from RC, I just assumed that Robison was the good stuff. Have their products gone down hill over the past few years? After a quick search, it seemed that people where having issues with this particular slipper.
Any advice would be appreciated.
oldpunk is offline   Reply With Quote
Old 02-23-2016, 06:45 PM   #2
Default Re: Robison gen3 slipper
You can't get no better than your purchase robinson Is bad ass shit top shelf get yourself the supershafty beefy top shaft and you are golden!!! " Thumbs-up "
rcaholic13 is offline   Reply With Quote
Old 02-23-2016, 07:09 PM   #3
What he said^^ I have the same setup, zero problems.
CrawlCrest is offline   Reply With Quote
Old 02-23-2016, 07:18 PM   #4
Cool. Thanks, guys. I already have the Robison idler gear and one piece locker so it made sense. I should start a build thread. You could point out my mistakes as I make them.
Old 02-23-2016, 08:34 PM   #5
You must have a Spawn with the dual slipper spur, yeah it's got a different top shaft to the other Wraiths.
Have you got the RR Wraith 80T slipper?
I'm not sure if that slipper is a direct fit with the SuperShafty top shaft, the shaft has a 2mm cross pin to suit the 2wd Slash slipper.
The stock top shaft only has a 1.5mm cross pin & the Robinson 80T slipper might only have a pocket to suit that.
Which is not to say the pocket couldn't be opened slightly with a dremel to suit the SS 2mm pin, just it might not bolt straight up.
altd896 is offline   Reply With Quote
Old 02-23-2016, 08:58 PM   #6
Yup, spawn kit. Thanks for the heads up. I will keep the dremal handy.
Robison gen3 slipper - Similar Threads
Gen3 slipper issue Bogncrawl Axial SCX-10 1 01-04-2014 12:10 PM
