06-05-2016, 06:52 PM | #1 |
Newbie Join Date: Jun 2015 Location: Gastonia
| Help!
New to RC. Got a new Spawn RTR kit not long ago. Ran it for two days on weekend I got it, next time I took it out the following weekend, throttle went out of control. Put new batteries in radio, ran for about 10 minutes or so, and the same thing happened. When the radio is turned off, the truck stops. Called tech support, and they sent me here. I think radio might be the problem. Any ideas? Tech support seemed to think it was a bad ESC, but very hesitant to send any new parts.
06-05-2016, 09:16 PM | #2 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
| Re: Help!
Run through the whole process of re-binding the receiver and re-calibrating the ESC. If it's still happening after that and the steering is working, tell Axial that their level 2 tech support (evidently us ) diagnosed it as a bad ESC and they should replace it. I have a Bomber that just had very similar symptoms and it was definitely the ESC.
06-06-2016, 11:27 AM | #3 |
Quarry Creeper Join Date: Mar 2015 Location: Woodland
| Re: Help!
What do you mean by throttle went out of control? I would also rebind everything, this is usually my first step when things are not working right with your electrics. I'm thinking esc too
06-06-2016, 08:18 PM | #4 |
| Re: Help!
I did the whole rebinding and calibrating the throttle first, before I contacted Axial, and the same thing kept happening. the steering would work, but the truck would not respond to input from the throttle. I got the truck out today when I got home from work to see how long it would run before the throttle went out again, and it ran over half an hour(until battery gave out). It was running in wet grass, which has me wondering if the ESC could be overheating during normal dry running. Not sure if that could be the problem. I really appreciate the help, as I have very limited experience with RC cars, and Axial seems to have limited experience with problems. |
06-06-2016, 08:52 PM | #5 |
Newbie Join Date: May 2016 Location: 209, CA
| Re: Help!
I agree with Mike. Probably ESC if the rebind and calibrate didn't fix it.
06-06-2016, 11:53 PM | #6 | |
| Re: Help! Quote:
