09-11-2016, 05:14 AM | #1 |
Newbie Join Date: May 2016 Location: Rockies
| Broke my new Wraith
Stripped the rear axle ring gear on my Wraith last weekend popping wheelies. Inspecting the set up after it happened I noticed both the front and rear pinion gear have forward/rear play. I got the new HD gears on Friday and plan to install today. Need to check for the same sloppiness with the HD gears and shim if needed. On my Wraith it looks like the shim will need to go on the pinion shaft outside the housing, between the bearing and driveshaft connection. I was able to find a few post pertaining to this scenario on the our forum, is this a common problem. |
09-11-2016, 06:47 AM | #2 |
Newbie Join Date: Dec 2015 Location: Pine knot
| Re: Broke my new Wraith
Yes its common.
09-11-2016, 08:37 AM | #3 |
Quarry Creeper Join Date: Aug 2015 Location: canton,oh
i had same problemshimmed did hd gears.... then locker started slipping. went to hh lockers hd gears shims and no problems now even with 3500 kv xl on 3 s |
09-11-2016, 11:47 AM | #4 |
Got her fixed this morning. I went ahead and replaced the transmission gears with HR steel gears and took the locker out of the front diff. It seems smoother with the HD diff gears. The Pug looks angry because he is a Browns fan.
09-11-2016, 12:13 PM | #5 |
Pebble Pounder Join Date: May 2013 Location: kinzers
yes being a browns fan should make him angry
09-17-2016, 08:57 PM | #6 |
I use the stock ring gear diff gasket even with the HD gears. I've found it helps with the mesh and needs less shimming.
09-17-2016, 09:13 PM | #7 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
After some time the inner bearings almost invariably fail and even the HD gears will slip. Get the AR60 modified housings from Dlux. He bores them out and adds a larger inner bearing so no shimming is required. They're only a few bucks more than the stock housings and I've never had one fail. |
Broke my new Wraith - Similar Threads | ||||
I think I broke it, wraith steamed/smoked a bit and won't work, help? | AJW | Newbie General | 20 | 01-09-2014 04:09 PM |
Wraith is broke help!!!! | mchury | Axial Wraith | 24 | 06-15-2012 11:58 PM |
My wraith just broke.....stripped gear I think | Ernie W | Axial Wraith | 16 | 11-04-2011 02:54 PM |
My thoughts on the Axial Wraith *UPDATE* 7/3 Broke | RPP Hobby | RPP Hobby | 11 | 07-03-2011 12:10 AM |
