11-15-2016, 06:45 AM | #1 |
Newbie Join Date: Oct 2016 Location: Wheeling
| Outcry ESC vs ae5
Came across the outcry the other day seems like you can't beat the price I've read some of the posts on here about it but not really a lot of info on it would it be better than the ae5 is it quieter caus the ae5 is so dam loud thanks in advanced guys for all your help
11-15-2016, 06:58 AM | #2 |
| Re: Outcry ESC vs ae5
Just say no to both ESCs! Check out the HobbyWing WP1060 or WP1080 for two great, inexpensive, and waterproof ESCs.
11-15-2016, 06:59 AM | #3 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Outcry isnt smooth down low nor does it has a lvc. Your choice.
11-15-2016, 07:18 AM | #4 |
| Re: Outcry ESC vs ae5 As well as the reliability issues of the Outcry. Get a HobbyWing. Trust me. You'll love it. The WP1060 is like the Axial AE-5, but it has the option of non crawler mode and no drag brake. Plus it's half the cost, but it's still waterproof. WP1060: HOBBYWING North America — QUICRUN 16 Brushed ESC The WP1080 is much more programmable and even comes with the programming card. Again, it's waterproof. WP1080: HOBBYWING North America — QUICRUN WP 1080 Brushed ESC for Rock Crawler For Dual motors: WP860: HOBBYWING North America — QUICRUN 08 ESC DUAL BRUSHED (2- 4S) |
11-15-2016, 09:20 AM | #5 |
Thanks guys I have the ae5 now in my wraith it works OK but just really loud and I don't think the drag brake is as good as the ae2 was
11-15-2016, 10:30 AM | #6 |
| Re: Outcry ESC vs ae5 I didn't like the AE-2, but it was world's better than the AE-5. If you're looking to upgrade over the AE-5 I'd suggest the HobbyWing WP1080. It has an adjustable drag brake whereas the WP1060 does not.
11-15-2016, 10:44 AM | #7 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
Just picked up a cheap AE-5 for a friend's Wraith and it blew up on it's maiden run. We were 40 minutes into some light crawling and suddenly his Wraith went WOT. We grabbed it and tried everything, but the ESC just went WOT from the moment a battery was plugged in. Axial is warrantying it for him but it's backordered so he won't even get a new one until later November. Previously, I had an AE-5 that worked ok but I killed on my own accord from abuse.
11-15-2016, 11:59 AM | #8 |
I've heard a lot of issues with the AE-5. I only have one. It came in my SMT10. I used it for less than 10 battery packs and it was fine, but that's not much of a test. I took it out for a brushless system.
11-15-2016, 02:53 PM | #9 |
Quarry Creeper Join Date: Aug 2014 Location: Chilliwack
I had the Outcry in my TF2, big mistake. No lipo cutoff, poor low end control and died after a dozen runs. Trying to figure out what to put in next, might try the Hobbywing
11-15-2016, 04:48 PM | #10 |
Ya I might have to pick up the hobbywing and keep the ae5 as back up I do like a ESC with drag brake and I can't seem to find to many of them
11-15-2016, 05:12 PM | #11 | |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: Outcry ESC vs ae5 Quote:
(being a drag racer I know a trans brake as a whole other component) Even a basic Castle SW3 has the option to turn on drag brake TowerHobbies.com | Castle Creations 1/10 Sidewinder 3 Waterproof ESC But a BR-XL is nicer again Holmes Hobbies TorqueMaster BR-XL - Speed Controllers - Electronics & Wiring Though both are more than the HW esc's. | |
11-15-2016, 05:16 PM | #12 |
Yes you are right I didn't know that about the castle ESC my mistake
11-15-2016, 07:50 PM | #13 |
I hate the Castle SW3. It's huge, not the smoothest and a royal PITA to program without a Castle Link. The HobbyWing WP1080 has limitations, but it's less expensive. I'd recommend the HobbyWing over the SW3 all day. If you insist on Castle look at the Mamba Micro-X. |
11-15-2016, 11:15 PM | #14 | |
For a trail rig I'd be a bit concerned about heat build up in unit with so small a heat sink but it could be alright. SW3 wouldn't be my first choice either, was more a reference to even it having drag brake. SW3 does have the 213% crawler DB option, the highest HW option is 100%...if that's a critical thing to your driving. At least the 1080 comes with the programming card as well https://www.amainhobbies.com/hobbywi...112750/p564169 Quite frankly they are ALL a PITA to adjust without an external programmer, if your still doing it any other way you need either need therapy or your shortly going to. Last edited by altd896; 11-15-2016 at 11:20 PM. | |
11-16-2016, 07:10 AM | #15 | |
Yes, the WP1080 comes with a programming card. And the best part is it has a separate programming port on the ESC. That way you don't have to open the receiver box, remove the leave from the receiver and plug the programming card into that. Instead you simply plug the programming card directly into the ESC. | |
11-17-2016, 06:43 AM | #16 |
Would I see a improvement if I would get the brxl I'm still running stock motor for now
11-17-2016, 07:53 AM | #17 |
Rock Crawler Join Date: Feb 2010 Location: Central/SE Ohio
FYI I burnt an ae5 this past Sunday; my truck took off and launched a 60ft cliff to flat ground. I'm never using brushed anything again. SMH
11-17-2016, 09:19 AM | #18 |
Dam that sucks man
11-17-2016, 09:40 AM | #19 |
| Re: Outcry ESC vs ae5 Yeah thank god my friend and I weren't crawling next to the river when his happened, we started hiking up a trail and suddenly it just cut loose. Otherwise someone would have been diving in the water after a brand new build...
11-17-2016, 11:18 AM | #20 |
| Re: Outcry ESC vs ae5 |
Outcry ESC vs ae5 - Similar Threads | ||||
ESC AE5 Connector to Battery | Wehlee | Electronics | 3 | 03-14-2016 03:24 AM |
