12-01-2016, 07:08 AM | #1 |
Newbie Join Date: Nov 2013 Location: Sweden
| Wraith with SCX10 Axles. Link lenght??
Hi Guys Im starting to put together a 1.9 Wraith.. i have seen allot of the on this forum, But i can´t find any good referens on "eye to eye" link length, front and rear upper/lower.. thanks in advance... |
12-01-2016, 08:46 AM | #2 |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
| Re: Wraith with SCX10 Axles. Link lenght??
I started with standard length SCX10 12.3 wheelbase links and then trimmed them back to get the axles where I wanted them. Some people leave the axles at stock SCX10 link lengths and are happy with that.
12-01-2016, 01:10 PM | #3 |
The rear links stay the same because the axle is already positioned well in back. I used Wraith links on the rear of my 1.9 XR10 width Wraith build and they we're perfect. The fronts are a different story. They have to be very short to get the axle pulled in to put the wheels in the right location but that's really up to you. Some like it to stick out in front a bit more than others. I used some Traxxas turnbuckles I had on hand with a combination of Jato and Revo ends and experimented until I got the front axle perfect. I then measured the lengths and ordered up some Ti links from VP.
12-04-2016, 09:09 AM | #4 |
Thanks for the advice guys. Do I still need to run bent upper links in the rear if I stay with the stock wraith length?? Skickat från min E5823 via Tapatalk |
12-04-2016, 10:49 AM | #5 |
Probably not since the driveshaft will be centered. That's the main reason those upper links are bent, to go over the driveshaft at full compression.
12-09-2016, 02:31 AM | #6 |
Pebble Pounder Join Date: May 2013 Location: new zealand
ill try have a measure of mine next couple of days because mine is all custom lenghts to get a correct looking wheel base. fronts are quite short, i have a panhard setup that is a mix of rc4wd/vanquise (think thats how they spell it) and custom links...ive had to mount links on the back side of alot of things to get good angles and matching angles on panhard and tie rod links etc. its more work but worth it to do customs cos alot of 1.9 wraiths look far to long
12-09-2016, 02:50 AM | #7 |
I would really appreciate if you have time to get some measurements of your links. Skickat från min E5823 via Tapatalk |
12-24-2016, 02:16 PM | #8 |
I'll get some pics and lengths up hopefully today
12-24-2016, 09:55 PM | #9 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
| Re: Wraith with SCX10 Axles. Link lenght?? Badd's Fusion 1.9 Wraith with SCX10 axles Check my first post in that thread . Look at pics to see how it came out . Maybe this will help you out . |
12-25-2016, 04:00 PM | #10 |
right got some lenghts and pics and info... front lenghts -upper 93mm -lower 97mm rear lenghts -upper 105mm -lower 110mm trackbar/panhard -82mm -rc4wd upper wraith mount with scx10 vanquish axle mount. top tie rod is mount on backside of mount, lower tie rod is mounted in front which you will hopefully see in pic below im using the stock plastic drive shafts which i have not had a problem with yet. i used the short front and long rear with came with the wraith kits the get correct shaft lenght without any cutting. im using raised shock mounts and g-made transtion shocks set non-droop and the shocks are mounted outside of the axle mounts which you will also see in pics....right pics tie rods are rc4wd med lenght from memory and i have a 25mm eye to eye servo horn |
12-25-2016, 06:11 PM | #11 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
When I made my 1.9'' Wraith, I used the same Axial Wraith aluminium links with shorter rod ends to shorten The wheelbase a little and I shortened the Wraith shocks by changing rod ends To get 100 mm's out of them and installed the SCX10 axles I put the AR60 axles back on it and running 2.2'' wheels again Using the SCX10 axles for a 1/6th scale build Last edited by kgb424; 12-11-2018 at 01:14 AM. |
12-27-2016, 07:30 AM | #12 |
thanks for all the info.. now i can get going with this build..
Wraith with SCX10 Axles. Link lenght?? - Similar Threads | ||||
Blue monkey link lenght | desertdude | Vaterra Ascender | 5 | 01-22-2016 09:37 AM |
What Link lenght you ride | alextronique | Axial SCX-10 | 2 | 03-09-2011 08:54 PM |
Lower link lenght | axman2010 | Axial SCX-10 | 4 | 02-03-2009 11:03 PM |
Lenght of link arms? | bro460 | Traxxas Crawlers | 3 | 05-05-2007 10:51 PM |
