Thread: drive line and suspension upgrade need advice
Old 04-16-2017, 03:36 PM   #1
Default drive line and suspension upgrade need advice
i god today a used axial wraith...
it already have a 35T motor. and TGY-5521MDHV servo.
upgraded drive shafts, and knuckes.
upper links, and i ordered a lower links too.
and steering link.
for some reason the shocks are diffrent i dont know why, but the rear shocks not work very well. so i want a new set. what brand or model should i chose?
king 110mm piggyback will work for me?
also looking for a lower gear ratio.
and aluminium axles. because the plastic is bad :(
best bang for the buck...
thank you
Big_White is offline   Reply With Quote
Old 04-17-2017, 08:11 PM   #2
Default Re: drive line and suspension upgrade need advice
Your rear shocks may just need a rebuild, they're probably dry. If you're set on getting new ones, Traxxas Big Bores (rears) are probably the best bang for the buck.
You can lower the gear ratio with underdrive gears (AX30402) in the diffs or a larger pinion.
Don't dismiss plastic axle housings too quickly. They don't hang up on rocks and are about 1/10 the price. I use Beef Tubes and/or trusses to stiffen them up and have never had a problem.
mikebecher is offline   Reply With Quote
Old 04-19-2017, 09:23 PM   #3
I like my plastic axles, I have the SSD diamond, and stock axles, stocks are fun and easy to use, slide easy and don't cost a lot
Thechewmaster is offline   Reply With Quote
Old 04-20-2017, 04:16 PM   #4
what oil i need to use when i rebuild the stock ones? i will use them in future in junkyard build..
already ordered a vanquish axles... the next step will be change skid plate. so i will have a lot of spare parts
how much teeth arm a TGY-5521MDHV servo use? i cant find information about that.
Old 04-20-2017, 06:11 PM   #5
I too am a big fan of the Traxxas Big Bores .
That said I'm now looking at a set of dravetech 's version. Much better performing and looking !
Price is right !
https://dluxfab.ecwid.com/#!/Dravtec...tegory=6232188
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 04-20-2017, 07:29 PM   #6
Price is right !
Hang up and Drive
If I could do it all over again, I would not have bought the various shocks I've purchased, and went with traxxas big bores, these dravtech ones look quite enticing
Old 04-20-2017, 07:35 PM   #7
I love my BB the dravtech just look badass !
Hang up and Drive
Old 04-28-2017, 10:43 AM   #8
Hang up and Drive
It looks lile the Dravtech's are reworked traxxas big bores.
Comp Shocks – DravTech
frontedge is offline   Reply With Quote
Old 05-11-2017, 07:22 PM   #9
I like the King 110 mm shocks have them on both our Wraiths!
pncstod14 is offline   Reply With Quote
Old 05-23-2017, 05:53 AM   #10
King?
Teng is offline   Reply With Quote
Old 05-23-2017, 07:39 AM   #11
Don't expect that servo to live long if you replace the stock plastic links
Ninomaniac is offline   Reply With Quote
Old 05-29-2017, 11:50 AM   #12
i think its already done his job LOL
drive line and suspension upgrade need advice - Similar Threads
Suspension upgrade Crawlernoob73 Tamiya XC/CC01 5 12-10-2016 11:01 AM
CKRC Yeti Drive line Upgrade. cullen colapietro Axial Yeti 3 10-21-2014 08:36 PM
Suspension upgrade Andyking Axial Wraith 2 11-13-2013 12:20 PM
What suspension upgrade next? HeavyG Axial SCX-10 6 04-08-2010 07:43 PM
Suspension Upgrade Easy Target Axial AX-10 Scorpion 5 07-09-2008 08:27 PM
