Thread: New add on
Old 05-16-2017, 05:30 PM   #1
Default New add on
Not sure if should be here....
Session 4
Simple mount for wraith
I use the small screws as locating pins for the hood. A simple pair of nuts lets me remove entire bracket quickly to get to battery .
Lot of fun seeing a drivers perspective from the Bluetooth app. Prices are a bargain for what it is
mikemcE is offline   Reply With Quote
Old 05-16-2017, 07:05 PM   #2
Moderator
JatoTheRipper's Avatar
Default Re: New add on
I was going to make one of these for a different vehicle. Nice.
Sent from my SM-N910V using Tapatalk
Old 05-17-2017, 06:50 AM   #3
Go Pro is OK, now set it up fpv. I found the weight of a go pro is enough to change the wraiths cg especially when climbing. FPV on a wraith climbing will just about make you sick to the stomach.
Have fun
chipgibbs is offline   Reply With Quote
New add on - Similar Threads
want to add 1 more xxx123 Newbie General 2 07-15-2014 03:21 PM
Add camobob Redcat Crawlers 25 05-16-2010 06:03 PM
do I need to add a BEC if I add a second servo? 5wattchamp Electronics 4 04-29-2009 09:54 PM
how much weight to add? 84CUCV Tires and Wheels 7 03-03-2009 07:46 AM
