08-05-2017, 02:37 PM | #1 |
Newbie Join Date: Oct 2016 Location: US
| Bearings?
I just purchased a box of wraith components and parts. Some good stuff and a few things needing to buy to complete my wraith. Anyways my biggest question is all the bearing kits the same between the versions of the wraith? I'm trying to order avid bearings in a kit but it has 5 options for different versions of the wraith. Sent from my SM-N920V using Tapatalk |
08-05-2017, 05:31 PM | #2 |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
| Re: Bearings?
The trans and axles are all the same across all versions. I can't see there being much difference. Sent from my SM-N920V using Tapatalk |
08-05-2017, 06:16 PM | #3 | |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
| Re: Bearings? Quote:
Qty 4 - 5mm id x 10mm od x 4mm thk Qty 11 - 5mm id x 10mm od x 4mm thk Qty 1 - 8mm id x 16mm od x 5mm thk Qty 6 - 10mm id x 15mm od x 4mm thk Qty 1 - 15mm id x 21mm od x 4mm thk As motorider says, I think all versions of the Wraith use the above listed sizes and quantites. | |
08-05-2017, 06:23 PM | #4 |
| Re: Bearings?
Thank you all. I got them on order . Hopefully will be here next week. Now to get my esc Sent from my SM-N920V using Tapatalk |
Bearings? - Similar Threads | ||||
Bearings | CamposZac96x | Axial SCX-10 | 1 | 11-14-2012 06:57 PM |
CC Bearings | Rockfrog | Duratrax Cliff Climber | 3 | 09-12-2009 11:20 AM |
bearings | jaythack11 | Newbie General | 9 | 02-22-2007 12:41 PM |
