Thread: Vanquish VVD binding
Old 09-14-2017, 04:58 PM   #1
Default Vanquish VVD binding
This short VVD for my wraith is binding when I tighten up the knuckle. If I loosen up one screw about 2 turns the knuckle loosens up and the axle spins freely. The bind in the axle rotating is only in one spot as if the shaft was bent. I checked the shaft as best as I could on a very flat surface and saw no noticeable wobble. The knuckle will not turn freely if both screws are tight.
Now the weird part is that when I put the stock shaft back in, everything is fine. Even weirder is that the VVD rotates and wiggled very freely when outside of the axle housing. The axle housing does have beef tubes in it.
I was trying to install these in my existing axle. I bought them used and will be disappointed it they are bad. I have had a strong of bad parts bought used here lately. Unfortunately I bought them weeks ago and am just now getting to use the parts. Also the locker was a fancy set screw 2 piece vanquish locker that had all the screws sheared off. So it's trash too. Vanquish no longer makes them so I can not get parts for it.
Sent from my SM-N920V using Tapatalk
Motorider is offline   Reply With Quote
Old 09-14-2017, 06:20 PM   #2
Default Re: Vanquish VVD binding
Are the knuckle screws hitting the vvd?
DrewHammer is offline   Reply With Quote
Old 09-14-2017, 07:53 PM   #3
I have had the same problem, the problem i had was that the tang was abit to long, and woud cause binding.
You coud try and grind down the end abit.
Rcdood is offline   Reply With Quote
Old 09-15-2017, 01:48 PM   #4
nope, the scuffs were there when I got them. The axles I have them in are better. There is no visible contact anywhere.
Old 09-15-2017, 01:49 PM   #5
I will be trying this. Easy to do and will harm nothing if you are wrong. It must me just a little tiny amount. Im going to try it now.
Old 09-18-2017, 06:41 AM   #6
So I attempted this mod. It helped the knuckle to move freely. I then found the chamfer to not be far enough back. That helped the rotating stickiness some. It still has a slightly tight spot in one point of the rotation. No idea what is causing it. I know that the stock u joint shaft works great.
Old 09-19-2017, 11:10 AM   #7
Stock lockers? I had an issue with binding when I had the HR set screw lockers. It was tough getting them exactly even when tightening them.
Farabomb is offline   Reply With Quote
Vanquish VVD binding - Similar Threads
Vanquish vvd goingvertical Axial Wraith 28 05-23-2017 05:49 AM
Vanquish VVD issue BlownChevelle Axial RR10 Bomber 4 11-13-2016 01:34 PM
Vanquish vvd rebuilds rc crawler boy Axial Wraith 16 06-28-2013 10:49 PM
Vanquish VVD GravelDuster Axial Wraith 3 08-24-2012 03:09 PM
