01-10-2018, 05:32 AM | #1 |
Pebble Pounder Join Date: Mar 2015 Location: france
| Heavy Duty Bevel Gears AXIAL vs HOT RACING
hi guys, wanted your feedback, I'm running currently the axial version but pricy !!! the HR version is 10 bucks cheaper has anyone been running them ? thanks LV |
01-10-2018, 05:56 AM | #2 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| Re: Heavy Duty Bevel Gears AXIAL vs HOT RACING
I have never run HR bevels, but I have had good experiences in Boom Racing HD bevel gear set on my Wraith( consider very reliable if you shim properly) In my humble opinion Boom racing and HR both were made in China. Either one will serve you well. Last edited by Teng; 01-10-2018 at 05:59 AM. |
01-10-2018, 06:25 AM | #3 |
I also run the Axial , but I do run the HR trans gears, well made and trouble free gears Hang up and Drive |
01-10-2018, 06:37 AM | #4 |
The SuperShafty BombProof transmission build uses Hot Racing gears... I'm building my Bomber trans with them as well. My diffs are under-drive Axial HD, but that's just because at the time I bought them I don't know if HR even had them available...
01-10-2018, 06:56 AM | #5 |
When it comes to gears I typically go OEM.
01-10-2018, 07:06 AM | #6 |
A lot of people used to run the HR gears years ago because they were cheaper than the Axial versions. I don't recall people having issues with them. Now, the Axial versions are basically the same price as the HR gears so everyone just goes with Axial. If the HR gears are still significantly cheaper in your area, then go with those. |
01-10-2018, 08:43 AM | #7 |
I learned the hard way with after market gears. I tried out RC4WD "hardened" set front and rear. They stripped the pinion and ring in the rear halfway through a run, and the front was well on its way when I inspected. The material they were made from was liked dried cheese! Went back to Axial units and have had zero issues since. Now, I will say all three of my HR trans are phenomenal and have had zero issues. So, it might be worth giving the HR units a shot.
01-10-2018, 03:20 PM | #8 | ||
| Re: Heavy Duty Bevel Gears AXIAL vs HOT RACING Quote:
01-18-2018, 01:15 PM | #9 |
Thanks guys for your feedback ! Envoyé de mon SM-G930F en utilisant Tapatalk |
01-18-2018, 01:56 PM | #10 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
If you do go HR let us know how they do. I'm curious on them as well.
Heavy Duty Bevel Gears AXIAL vs HOT RACING - Similar Threads | ||||
Axial Heavy Duty Bevel Gear Set 43/13 | guidetti_angelo | General Crawlers | 1 | 05-15-2012 08:32 PM |
