Thread: My scratch slim wraith build... The trim trailer....
Old 08-16-2018, 06:21 AM   #1
Default My scratch slim wraith build... The trim trailer....
Starting on a new project
It is a wraith with scx10 axles, and traxxas 2.2 wheels(at this stage)
I'm not really doing it for any reason other than I can, so I'm excited to see where I take this.
I have ssd D60 axles with stock gears, ssd Pro steering kit, RC4WD delrin wraith skid plate, ssd high ratio transmission, tekin 5mm 4pole 4000kv sensored motor, I have a MMX to put in too, and I think I'll also chuck on my 2290sg
I started tonight, keen for input, and I'll keep this updated as I go along
Sent from my LG-H870DS using Tapatalk
Stray is offline   Reply With Quote
Old 08-16-2018, 06:23 AM   #2
Default Re: My scratch slim wraith build... The trim trailer....
Found some shocks for it
Old 08-16-2018, 08:53 AM   #3
Subbed. Keep it up.
Brake Weight is offline   Reply With Quote
Old 08-16-2018, 11:31 AM   #4
Subbed as well as I am a step or two behind you in my own build.
maxinflixion is offline   Reply With Quote
Old 08-17-2018, 02:29 AM   #5
Front axle coming along,
Need a new drag link as this one is for a cms....
Old 08-17-2018, 04:34 AM   #6
Back end shortened up
Old 08-17-2018, 05:02 AM   #7
Well an hour later, some allthread, bolt cutters, and ssd rod ends... We have a much shorter wheelbase.
Starting to look good!
Have moved to 1.9 wheels for now...
Old 08-17-2018, 05:51 AM   #8
Right so I have WAY to much motor.... I have some other options I'll look into...
And I have some swb issues with the servo.
Basically the truck has no front travel... See pics.
I wonder if I can get a suitable low profile servo?
Old 08-18-2018, 05:54 PM   #9
Problem solved for now, slightly longer front wheel base, and a low profile servo mounted slightly forward. Not sure how long the servo will hold up......
Old 08-22-2018, 05:25 AM   #10
I changed out the ssd axles for some stock scx10 axles I had, gave me better servo clearance, and is more inline with my vision... I still need to change the wheel base around a bit, shorten the front and maybe lengthen the rear. But it's all working now....
Next item is the find a more suitable motor. I have an 1800kv sensored motor somewhere that I think will work well...
Ill update when I've made the changes
Old 08-22-2018, 05:26 AM   #11
I changed the shocks out too, running 90mm internal spring
My scratch slim wraith build... The trim trailer.... - Similar Threads
Scratch build wooden trailer JoeConti Scale Accessories 0 05-05-2018 12:23 AM
My Scratch 4WS Wraith Build haleymon Axial Wraith 14 06-28-2015 11:44 PM
Wraith Build (from scratch) XS NOIZ Axial Wraith 12 09-12-2014 10:44 PM
Wraith knock off scratch build DonnieB 2.2 Scale Rigs 2 05-20-2013 08:42 PM
