07-16-2016, 02:49 PM | #1 |
Rock Stacker Join Date: Apr 2012 Location: zeeland
| Locker
WhAt is the best diff locker for the money? I keep breaking the stock locker and need an upgrade but don't know which to get. Sent from my iPad using Tapatalk |
07-16-2016, 03:57 PM | #2 |
Quarry Creeper Join Date: Feb 2015 Location: Norway
| Re: Locker
Lot's of good locker's on the market. Ive tried Grip Fab and Incision versjon, and pretty happy with both. Last edited by Rcdood; 07-16-2016 at 07:48 PM. |
07-16-2016, 04:03 PM | #3 |
I joined the Band! Join Date: Feb 2015 Location: On a rock
| Re: Locker
Holmes Hobbies spool, or no spool. Want the least amount of slop? Go HH.
07-16-2016, 07:23 PM | #4 |
| Re: Locker
The FI spools from Locked RC also work great with little slop.
07-16-2016, 07:50 PM | #5 |
| Re: Locker
Remember to not use the gasket on the new lockers you get, just a headsup |
07-16-2016, 08:52 PM | #6 |
| Re: Locker
Thanks for the info guys! Sent from my iPad using Tapatalk |
07-16-2016, 09:31 PM | #7 |
| Re: Locker
I just got a pair of the 300m spools from BMRC and they are very nice. Grip fab, locked up RC, Holmes, Any of these are great choices. I'd see if Blue Monkey is still running his 2 for 1 deal. Great way to save $20.
07-17-2016, 03:56 PM | #8 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
| Re: Locker
Hot racing spools are great
07-18-2016, 12:57 PM | #9 |
Quarry Creeper Join Date: Mar 2015 Location: Woodland
| Re: Locker I have these, just an FYI. I got bound up where I could not see yesterday. Tried to gass out, mistake. Snapped an Axial Universal about an inch front he locker. Locker is 100% perfect, no issues.
07-18-2016, 08:05 PM | #10 |
Newbie Join Date: Jan 2015 Location: Oklahoma
| Re: Locker
Hot racing here also. 9 lbs rig no problems yet.
07-18-2016, 08:36 PM | #11 |
Rock Crawler Join Date: Feb 2010 Location: Central/SE Ohio
| Re: Locker Ugh, I bought an HR spool in a brick and mortar shop in a pinch to make it through a session with my brother after blowing up my stocker, and the HR has more slop in it than the stock sintered locker. I wouldn't reccomend an HR. Yes it still works but there are much better options out there for similar money. I keep hearing lots of good things about the grip fabs. Think I'll go that route when I blow up my HR. The Vanquish Locker is a really neat piece of kit with the whole "floating" design using o-rings and all but I'm not a fan of the set screws to elimnate slop, I think a true spool style with tight cnc tolerance is the better way.
07-19-2016, 06:40 AM | #12 | |
| Re: Locker Quote:
07-19-2016, 09:51 PM | #13 |
Quarry Creeper Join Date: Apr 2016 Location: Canada, Ottawa/Gatineau
| Re: Locker
The whole point of buying after-market lockers is to get rid of the slop on top of the added strength, therefore the addition of Loctite on an after-market replacement as Axial requires with their sintered version kinda voids the whole purpose. Go with a better quality like Locked Up RC, Vanquish, Incision and Holmes. |
08-10-2016, 02:38 PM | #14 |
| Re: Locker
I ended up getting the blue monkey spools and they looked like they would be great. After a few runs the front spool is shot! It looks to me like the long axle shaft does not slide into the spool far enough. It only went in about 1/16 of an inch. So now my axle shaft is slightly rounded and the spool is stripped out. What spool with solve this problem? Sent from my iPad using Tapatalk |
08-10-2016, 03:12 PM | #15 |
Rock Stacker Join Date: Jul 2016 Location: In the shadows
| Re: Locker
I would recommend Locked Up Rc's FI spools. "FI" meaning -f#&$n indestructible. They are a very tight fit and for about $20 apiece- IMO cant go wrong there. I've also used Vanquish spools w floating design- pleased, expensive but pleased. Incision- price good, performance and slop -piss poor. Havent got my paws on a set of Holmes spools yet, but would definitely try Locked Up FI. Good luck.
08-10-2016, 03:25 PM | #16 |
| Re: Locker
This is the second time in less than a week that I've heard of the BMRC 300m spool failing because of poor design and insufficient axle shaft engagement. I'm going to send Matt an email and see what he thinks. I'm really hoping I can find a use for the two brand new ones I have. Please don't say paperweight.
08-10-2016, 03:44 PM | #17 |
| Re: Locker
Thanks for the insight rock farmer. Screamer, the blue monkey spool is working fine in the rear of the truck but not the front. The axle shafts engaged more in the rear than the front. Just don't use them in the front. Sent from my iPad using Tapatalk |
08-10-2016, 03:48 PM | #18 |
| Re: Locker
Oh that's good to know. Thanks Maxx. I don't mind at all using them only in the rearend as long as I can use them. I sent that email to Matt at Blue Monkey so hopefully he looks into it and chimes in.
08-10-2016, 04:12 PM | #19 |
| Re: Locker
There seems to be an issue with a few lockers out there not having enough engagement in front applications. I've had issues with vp's floating style, felsenfest and another clamping of unknown brand. All of them worked fine in the rear. The front shafts just don't go in deep enough. The issue with the bmrc spools just accentuates the issue. |
08-10-2016, 05:29 PM | #20 |
| Re: Locker
Wow, I wasn't aware of that. I know VPs VVDs have longer tangs and engage more of the locker in front and I run 3-4 sets of those so maybe why I haven't had any issues with any of my spools. WT, I'm sure you've said before, what's your front locker of choice or front and rear for that matter? Holmes?
Locker - Similar Threads | ||||
Has any one else had there HR locker do this? | MacJamez | Vaterra Twin Hammers | 8 | 05-26-2014 08:07 PM |
locker | hodges996 | Axial AX-10 Scorpion | 7 | 02-18-2009 01:36 AM |
Best locker | RockCrawlingKid | HPI Wheely King | 17 | 02-01-2008 03:04 PM |
Need a locker or 2 | Golfcrawler | General Crawlers | 1 | 01-26-2007 08:27 AM |
