12-12-2013, 09:23 PM | #1 |
Rock Stacker Join Date: Jun 2009 Location: Indonesia
| XR10 Front Axle in the back VS Rear Axle
Hello ppls, I would like to ask opinion about using XR10 front axle in the back (rear), can anyone give me opinion about its advantage vs using rear axle ? ( beside less gear strip of course ). I noticed ppl like hittman and John hall use front axle in rear instead of rear axle. Any comment/opinion will be appreciated. thanks in advance. |
12-12-2013, 09:54 PM | #2 |
RCC Addict Join Date: May 2012 Location: Folsom
| Re: XR10 Front Axle in the back VS Rear Axle
You gain a bunch of clearance, rear shock geometry changes, And you wb will shorten up because of the way the lower links mount to the axle.
12-12-2013, 10:43 PM | #3 | |
| Re: XR10 Front Axle in the back VS Rear Axle Quote:
Thanks in advance. | |
12-12-2013, 11:24 PM | #4 |
Your rears upper links will be a little to long and the lowers will be too short by about 1/8 to 1/4 in. That can be fixed with longer rod ends usually
12-12-2013, 11:33 PM | #5 |
| Re: XR10 Front Axle in the back VS Rear Axle |
12-13-2013, 12:12 PM | #6 |
Rock Crawler Join Date: Jun 2011 Location: San Diego
You really don't need it. So many people who run the adjustable holes run their links at or below the stock mounting location. It's really a minor thing compared to the rest of the rig.
12-13-2013, 05:33 PM | #7 |
12-17-2013, 09:09 AM | #8 |
Rock Crawler Join Date: Oct 2012 Location: Trail B.C.
If I am not mistaken to run the front axle in the rear you need to get a different set of drive shafts for it as well. I believe the original idea to use the front in rear was to save gears as the rear axle has a habit of popping final drive gears. You can do the 2 screw mod to help save the gears inthe rear axle. XR10 2 Screw Mod Last edited by jaloos; 12-17-2013 at 09:11 AM. |
