09-26-2010, 07:48 PM | #1 |
| Bearings
Whats everyone doing for bearings ? I'm looking at Avid bearings rubber shielded. http://www.avidrc.com/flexkit/?kit=271&kitname=Axial%20XR10%20(AX90017) |
09-26-2010, 07:53 PM | #2 |
I would get bushings, they handle loads better properly lubricated, and since they are easier to make, cheaper.
09-26-2010, 07:57 PM | #3 |
Don't they wear out faster ? Even properly lubed ?
09-26-2010, 08:12 PM | #4 |
RCC Addict Join Date: Feb 2006 Location: ccxc
09-26-2010, 09:37 PM | #5 |
i think someone was talking about the wear concerns on the bushings versus bearings and the answers i think i remember involved the difference between a crawler...well...crawling and a dirt track racer...racing i think the material that VP chose to use is more than up to the task of handling the forces at work in the XR as well as lasting longer than youd think...obviously theres no way to say how long they actually will last |
09-26-2010, 09:53 PM | #6 |
RCC Addict Join Date: Dec 2005 Location: Tucson
bushings for now till the new transmission case and motor plate comes out. But the VP bushing fit the motor plate better than the bearings do.
09-26-2010, 10:52 PM | #7 |
Rock Crawler Join Date: Mar 2004 Location: Albany
Im running the Avid rubber sheilded bearings until VP plates release them y 5x10 rubber shielded Avids will go in those to so far so good with them.
09-26-2010, 10:54 PM | #8 |
09-26-2010, 11:39 PM | #9 |
Keep Crawling in Crawling Join Date: Jan 2009 Location: Commerce City
I have been running ceramic bearings and have had no issues.
09-27-2010, 12:07 AM | #10 |
RCC Addict Join Date: Jun 2009 Location: California
Ran my bronze bearings all day...They seem fantastic at the moment....Its a great fix that guaranties no bearing failure....As for me I will run the Bronze bearings until VP finishes there new trans... |
09-27-2010, 12:09 AM | #11 |
I wanna be Dave Join Date: Mar 2008 Location: Pacific Ocean
I'm using Avid metal shield flange bearings. $1 ea anf they're surviving quite well. Just add a thin layer of CA to the inside of the motor mount, let it dry, and you'll get a nice snug bearing fit.
09-27-2010, 06:36 AM | #12 |
09-27-2010, 07:49 AM | #13 |
RCC Addict Join Date: Jul 2009 Location: Farmington, NM
I'm running Avid Metal Flanged, and Ceramic for the 4 case ones and have had no issues
09-27-2010, 11:50 AM | #14 |
09-27-2010, 11:59 AM | #15 |
Rock Stacker Join Date: Aug 2010 Location: nantucket
09-27-2010, 12:00 PM | #16 |
09-27-2010, 12:06 PM | #17 |
09-27-2010, 12:07 PM | #18 |
| It was a lot of heart ache and help from other members on here. You can go to Acer Bearings and order their XR10 ceramic bearing kit for $89.99. Went checking out put the code in "rccrawler" and it will give you an additional 10% off. The bearings should ship for free and your total should be $80.99. Here is the link: http://www.acerracing.com/ball_beari...it-1277-0.html I had a few issues with them and there initial pricing but I think it is all fixed now. Hope this helps. |
09-27-2010, 12:09 PM | #19 |
RCC Addict Join Date: Jun 2008 Location: Nunya Idaho...
09-27-2010, 12:11 PM | #20 |
| The place. Here is the link to the thread: Don't you hate it when a company....... This should explain it. |
