09-27-2010, 11:39 AM | #1 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
| XR10 Shock Setup & Tuning
I would like to start a thread for XR10 shock setup and tuning Feel free to post your XR10 shock setup, brand, type, spring, etc Please list reasons and terrain that cause you to run a specific setup or any other variables we may like to know about. My current XR10 shock setup: Front: Axial 72-103mm comp shocks Piston - Delrin Oil - 40wt Spring - Losi Gold Shock length - 108mm Rear: Axial 72-103mm comp shocks Piston - Delrin Oil : 40wt Spring - Losi Gold Shock Length - 108mm Last edited by Rig Rocker; 09-28-2010 at 11:37 AM. Reason: changed |
09-27-2010, 11:50 AM | #2 |
RCC Addict Join Date: Jun 2009 Location: California
Figuring everyone runs a different shock setup...Don't know the success on this being a sticky... But.... machined piston front/rear Stock weight Gold Losi springs front/rear...Softer the better. |
09-27-2010, 11:52 AM | #3 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
Sounds like a go setup, how smooth is the shock travel compared to stock form?
09-27-2010, 11:53 AM | #4 | |
Rock Stacker Join Date: Aug 2010 Location: nantucket
Im totally intrigued at finding out what shock set ups other people run....it might give me ideas on how to run mine better. | |
09-27-2010, 12:55 PM | #5 |
Didn't mean to be negative, or rude...I guess I'm just looking at this thread differently then others.... |
09-27-2010, 01:11 PM | #6 |
Shock oil, piston, and spring rates are dependent on each rigs suspension geometry, overall weight, weight bias, ride height, full droop height, ect. If you want this thread to reach its full potential you should list a lot more info Your shock setup may not work for someone running a rig 1lb heavier or lighter than you. O yeah, don't forget terrain REALLY comes into play as well! Best thing you could do is start a thread where everyone can share their XR10 setup sheet and explain their setups/changes. http://www.axialracing.com/ftp/pdfs/...setupsheet.pdf |
09-27-2010, 01:14 PM | #7 | |
09-27-2010, 01:48 PM | #8 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
You're missing Brandons point. I can take the shocks of your truck, which may work very well, and put them on my truck and it makes my truck a pile of poo. There is alot more than just shocks. Shocks are a big part of it, no doubt, but they need to be set up for each truck. I agree with the set up sheet sticky but a shock tuning sticky is kinda useless.
09-27-2010, 01:55 PM | #9 | |
09-27-2010, 08:42 PM | #10 |
Rock Crawler Join Date: Aug 2008 Location: Portland, Maine
This thread is definately sticky material |
09-27-2010, 09:04 PM | #11 |
Quarry Creeper Join Date: Jan 2010 Location: GV
Your mom is stic...... Never mind |
09-27-2010, 09:27 PM | #12 |
Rock Crawler Join Date: Oct 2009 Location: SO CAL
09-27-2010, 09:44 PM | #13 |
09-27-2010, 09:58 PM | #14 |
If filling a sheet out....It was still a good idea to post setups....I will post mine soon....
09-27-2010, 11:46 PM | #15 |
Pebble Pounder Join Date: Mar 2008 Location: K-ville
duratrax 3.5 rpm white pistions ta 20w oil losi golds doug cups traxxs ends |
09-28-2010, 01:24 AM | #16 |
Okay guys. Feel better? I started a new setup and tuning thread Axial XR10 Setup Sheet and Tuning guide Last edited by Rig Rocker; 09-28-2010 at 11:39 AM. |
