10-01-2010, 11:30 AM | #1 |
Quarry Creeper Join Date: Dec 2009 Location: San Jose
| front axel help
Dudes i need help...no, not mental help.... i already know you guys cant help me with that... i built my front axel last night. i noticed it is insanley hard to turn by hand. i added grease and followed instructions / advice but it sure seems tight. can anyone speak to wether or not the gears/cvds should be really tight to turn by hand? i dotn want to break this bastard until i have to. so yea, a little help brothers? thanks guys paul |
10-01-2010, 11:34 AM | #2 |
Quarry Creeper Join Date: Sep 2009 Location: Concord
That's normal. Think it's the cyntered gears. I just went easy on it for the first couple packs. It's smoother now.
10-01-2010, 11:40 AM | #3 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
put your rims on and then try.
10-01-2010, 11:43 AM | #4 |
10-01-2010, 12:27 PM | #5 |
RCC Addict Join Date: Jul 2009 Location: Farmington, NM
If your motors are installed, yes, put the rums on and try like they said. If motors aren't installed, no it shouldn't be hard to turn.
10-01-2010, 08:28 PM | #6 |
Quarry Creeper Join Date: Jan 2009 Location: Rocklin
The bearings suck try some avid racing bearings.
10-01-2010, 08:34 PM | #7 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
Thats wierd my axles spin really smooth without the motors mounted
10-02-2010, 07:17 AM | #8 |
Yah upgrade the bearings To Avid's or VP's bushing while your at this stage. Don't even bother with the factory bearings
10-02-2010, 07:40 AM | #9 |
Rock Stacker Join Date: May 2010 Location: Dayton,Tennessee
Me and my buddy built xr10 at same time took our time did it right and all my axles turned free but one of his was very hard to turn even with wheels and tires on it so he tore his apart and found one of the bearings had come out of its housing and was laying against the gear he put it back in made sure it stayed now his turns freely.
10-02-2010, 08:37 AM | #10 |
Thanks for the advice all. I will get off my ass and open it back up. I don't have the motor installed.... duh duh duuuhhhhh...... So- i will check and see if i have a "mod" going on. I did notice it was much easier before i greased them to turn. But I'm going to open the damn thing again and see |
10-02-2010, 08:54 AM | #11 |
I've cracked mine 4-5 times now each, it's 2nd nature and easy once you get used to it. I still have yet to have any failures either. Then again I installed Avid bearings from step 1, the stock bearings never even saw my case
10-02-2010, 09:35 AM | #12 |
Quarry Creeper Join Date: Jan 2008 Location: Citrus Heights
I was changing a pinion last night and saw peices so I opened it up and 2 of the flanged bearing were in peices. So i installed the bronze bushings and its a little louder now. I have avids in the back and they seem to be doing fine. |
10-02-2010, 11:02 AM | #13 |
10-02-2010, 10:20 PM | #14 |
so is the concencus that opening them and sealing them a couple dozen times over the life of the axels is acceptable considering all this tightening ? I have two SCX10s... i have taken the axels apart probably a dozen times and i don't see any issues with the seals becoming worn or tired...welll not seal but you guys know, the threaeded holes and the tounge and groove...(hehehe tounge and groove ) so yea, i guess i sound like a Nancy but you guys dfont think this is an issue? I bought an extra set at the LHS... they were 20.00 for the pair, seemed like it was worth it. thanks paul |
10-03-2010, 06:19 AM | #15 |
| The opening the axles yes. I took apart my bergs constantly. Whether or not the plastic will hold up to all this is a whole other story
10-03-2010, 08:40 AM | #16 |
Quarry Creeper Join Date: Sep 2008 Location: Rocklin
Just buy some avid bearings they are only a $1 each here are the links Flanged http://www.avidrc.com/product/8/metr...-bearings.html http://www.avidrc.com/product/8/metr...-bearings.html not flanged http://www.avidrc.com/product/8/metr...-bearings.html |
10-03-2010, 10:45 AM | #17 |
Holy cow!!!! Only a buck, that is so refreshing...thanks guys Paul |
10-06-2010, 09:37 AM | #18 |
i finally got a wheel mounted to the front axel. when i slowly spin the axel, i feel a rough spot 3 times in a complete rotation. I HAVE NOT gotten the time to take her apart yet, since i still feel this roughness i am going to crack it tonight... did you guys notice any roughness? or like a bur as you spin the wheel freely? i do not have a motor mounted. the axel is complete and its greased. Maybe a bur on a gear or the casing? (i will record this with photographic accuracy for you all to see if there is an issue) you guys all reccomend replacing the stock bearing right? avid as the brand? anything better? did any of you use some graphite lube on the steering rod? it also seems to stick just a tiny tiny tiny bit.... nothing major but i want my 7980 to last as long as it can. i may lightly polish the guide for the steering rod..or whatever the hell that is called. thanks as always dudes... paul Last edited by avoidsthelight; 10-06-2010 at 09:41 AM. |
10-06-2010, 09:54 AM | #19 | |
10-11-2010, 11:54 AM | #20 |
| ok, opened this back up the grinding went away when i put her back together but i couldnt find any reason why it was rough in patches. i took picks, i will post them tonight, they are at my house system...no rdp into my home network i would have them now... anyways, the front axel, the first gear - the arrow points outward, as the instructions call for right? this is the correct position? so the first gear in, the arrow is pointing inward. then, the outer gear, the arrow is facing inward....just like the instructions state. i will post images at lunch, ill run home. one more thing guys. has anyone found that one of 3x15mm self tapping screws looks more like 3x16mm? i noticed this last night, during the tear down, that one screw looked jsut a skaoch longer.... i measured and it looked more like 16mm. anyone else see this? thanks as always dudes paul |
