10-15-2010, 06:37 PM | #1 |
Pebble Pounder Join Date: Oct 2008 Location: Bartlett/ Memphis
| axial kit beadlock screws
Man, maybe im using a cheap driver or the screws are cheap. or maybe im trying to tighten them to much, im just trying to get the ring flush mounted. and im stripping out my screws. anyone else? I thought about tapping the holes for threads on a bigger screw. like a #4 maybe or something. using integy hex head drivers |
10-15-2010, 06:40 PM | #2 |
Use your fingers and squeeze the the beadlocks down so the screw doesn't have to.
10-15-2010, 06:41 PM | #3 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
Had issues with that also. I just tried to keep good pressure on your driver like your pushing the bit into the srcew. Thats what worked for me.
10-15-2010, 06:45 PM | #4 |
I went looking around for some different screws, couldnt find any at local places. checked 2 different hobby shops. no chance. i have one whel left for it . ill try these tips.
10-15-2010, 06:49 PM | #5 |
would it be the tires? im trying to mount panthers.
10-15-2010, 06:51 PM | #6 |
If you have any super glue, or CA glue, you can kind of repair the damage. Get a drop of glue in the hole and screw it down, and let it set. Make sure you don't get too much glue in there and glue the wheel to the tire to the beadlock ring. |
10-15-2010, 06:55 PM | #7 |
Rock Crawler Join Date: Mar 2008 Location: hillbilly illinois
10-15-2010, 11:25 PM | #8 |
Quarry Creeper Join Date: Apr 2008 Location: upland
i had the same thing, counter sink the rings a little bit more and run 4/40,no tapping, no drilling.
10-16-2010, 12:11 AM | #9 |
Rock Crawler Join Date: Jan 2010 Location: In the office, working on RC Projects!
Had the same issue, mine turned out to be the drivers. Bought some higher quality ones, instantly solved the problem. Dynamite Machined Hex Driver set (4) Metric = $30 |
10-16-2010, 04:08 AM | #10 | |
Yeah, i went and bought some new tips for the 1.5mm driver thinking that would help. it did some. also found that a 1/16th hex standard size fits it snug too. | |
10-16-2010, 04:25 AM | #11 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
I was using a brand new hex on mine and they still started stripping. I am going to order a bunch of 3 mm from mcmastercarr for mine. Or a new set of aluminum vanquish dh's!!! |
