10-29-2010, 04:03 PM | #1 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
| xr10 parts and custom made parts build
here are the parts i used on my build, along with some i made . Axial Xr10 ax30519 6x101 tube (30 degree) bent links for uppers ax30469 machined bent link for the lower futaba 4pk CC 10 amp bec hitec hs 7980 th hv servo HOT RACING axr2101 alum high steering knuckles axr1901 alum c-hubs axr2201 alum rear axel lockouts scp1001 12mm clamp on hexes saxr36fg lt. weight cnc steel final gears saxr1000t lt. weight cnc steel gear sets acer ceramic bearing set tekin 35 turn motors, and fx-r esc's traxxas revo steering linkage turnbuckles and rodends hanger 9 clampon servo horn hotbodies roaver in rear-stock foams sedonas in front memory foams losi gold springs front, gray in rear tunigy 40c 1300 mah 3 cell lipo rccrawler's jeepndoug spring retainers all 4 CUSTOM PARTS electronics plate, battery holder,steering knuckle plate,body mount,wheel weight, motor skids,receiver and esc mounts. Last edited by stelerzman; 06-16-2012 at 07:16 AM. |
10-29-2010, 06:14 PM | #2 |
Quarry Creeper Join Date: Jan 2009 Location: Rocklin
Good choice on parts(-HR)... Get that thing together and take some action pics!!!!
10-29-2010, 06:42 PM | #3 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
Now thats what I'm talk'n about I like the eletronics tray.
10-29-2010, 08:48 PM | #4 |
Rock Crawler Join Date: Jun 2010 Location: Yelm,WA
Looks like your rear links are backwards, might give you more clearance to turn them around |
10-29-2010, 09:52 PM | #5 |
Pebble Pounder Join Date: Dec 2009 Location: oregon
nice build but it looks like you got the chassie backwards or is it just me |
10-29-2010, 10:06 PM | #6 |
Rock Stacker Join Date: Feb 2010 Location: Manila
Yup, chassis is backwards. The longer tail of the chassis goes in the rear. The single body post should go right into the dimple on the roof of the body above the windshield. Also, it looks like you might need to clock your axles a little. The motors are hanging too low or at least from what I can see in the pics. |
10-30-2010, 03:35 AM | #7 |
RCC Addict Join Date: Nov 2009 Location: Tulsa
Looks cool man. I'm trying to figure out what's going on with thoes body mounts. What r they?
10-30-2010, 09:22 AM | #8 |
I wanna be Dave Join Date: Jul 2008 Location: appleton
Nice list of parts lets see some action shots
10-30-2010, 10:03 AM | #9 | |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
On the shock spring retainers- it's JeepinDoug, not dougnjeep Last edited by gunnar; 10-30-2010 at 10:07 AM. | |
10-30-2010, 11:19 AM | #10 |
Quarry Creeper Join Date: Sep 2008 Location: Rocklin
Looks good! What material did you use for the electronics plate
10-31-2010, 05:50 PM | #11 |
10-31-2010, 05:52 PM | #12 |
10-31-2010, 06:02 PM | #13 | |
10-31-2010, 06:06 PM | #14 |
| They are nylon screws and nuts from ace hardware, the black fastners are hard rubber i found in the plumbing section. I cut of a bit to make it easier to turn with my big fingers |
10-31-2010, 06:14 PM | #15 | |
10-31-2010, 06:26 PM | #16 |
10-31-2010, 07:58 PM | #17 |
| action pic's more to fallow. |
11-01-2010, 04:49 PM | #18 |
| here are some pic's of the frontend. springs,cups,hr gear and custom steering plate( in yellow ) this is the process i took to make a better steering plate. it moves the servo linkage forward to parallel to the servo, less strees on the servo. last process is paint to choice.( YELLOW ) for me.. |
11-02-2010, 09:28 AM | #19 |
Quarry Creeper Join Date: Oct 2008 Location: florida
11-02-2010, 03:55 PM | #20 |
im not upset at all, just letting them know thats the way i do things. see ya sun. |
Tags |
custom setup, custom xr10 chassis., xr10, xr10 chassis, xr10 setup. |
