11-04-2010, 06:24 AM | #1 |
Newbie Join Date: Aug 2010 Location: Prince George BC Canada
| Bec abuse
Well I built my xr10. installed a castle bec and went on my first trip up the rock. (creek) Flipped the car a few times and got the bec wet. The castle quit working. I blew into it and it fired back up again(got wet) I am not a fan of the cc bec as I have had nothing but problems with em. So anyhow I removed the castle bec for now. (I water proofed it if I need it again) I recieved my 7980 servo (man that thing is huge) threw it in. I am doing a no no thing but it seems to work just fine. around the house I am running both my fxr tekin esc's into the reciever with the red wire attached on each esc, and I am running my hitec 7980 servo to the reciever. And I have great steering and no glitching. Temps on the esc's are at 3 (out of 6) driving it around the house climbing walls and steering on the rug. I am going to try it this weekend on the rock again. I am tihnking I am going to be just fine. I guess I'll find out on sunday |
11-04-2010, 08:44 AM | #2 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
Bind it up and the problems will start |
11-04-2010, 09:13 AM | #3 |
RCC Addict Join Date: Jun 2008 Location: Fresno
im w/ pdog on this one remember, ur running 2 motors and an ultra torque servo. you wont be able to maintain the amount of voltage you need for such a high output servo |
11-04-2010, 09:23 AM | #4 |
| x3. When you start putting real world forces on it things change fast. Just be sure to keep a close eye on things unless you have tons of disposable income, electronics fires suck. I have lost $1500 worth of brushless converted Mugen buggy do to an esc fire. It was just too far away (about 300 yards of sand) for my fat ass to get to it quick enough when it went up.
11-04-2010, 09:48 AM | #5 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
I am suprised you are not having issues with the BEC's on the FXR's fighting. I know a guy that nuked his recevier when he had the red wire on both speed controllers plugged in. I am running both of my S9157 futaba servos on CC BEC's (at 6v) and no problems so far. I know when I was running the standard BEC on the FXR in my scaler, with two servos and 4 wheel steering, I could get the FXR to shut down on thermal overload because of the servos and lots of motor. Since I put in the CC BEC, it hasn't shut down once. |
11-04-2010, 09:53 AM | #6 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
I have fried a couple CC BEC's too. But I still think they kick total ass and would not run anything else. i too got one wet. I also kept breaking a lead off on side or the other, frying it, or just having it not work. I have sent every single one back to castle and got new ones. I have also started to cut the leads to the specific length i need. This prevents me from bending wires back and forth when i am fixing or adjusting stuff on the rig. |
11-04-2010, 11:31 AM | #7 | |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
Just posted this in another thread, so I'll quote myself: Quote:
11-04-2010, 07:49 PM | #8 |
Well I'll find out how she works on sunday. Works great so far in the house. If need be I'll throw that god damn cc bec back in but I have a feeling if push comes to shove, I am gonna do what i did on my ax10. Lipo 1300mah 2s battery direct to the reciever. I'll probely buy a smaller 2s lipo maybe 910mah or something and run that on top of the reciver box on the xr10. I really hate those cc bec's |
11-04-2010, 08:35 PM | #9 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
The key woed is in the house. I mocked my XR's steering up with a spectrum servo. 100in oz and plastic gears and it crawled the couch fine and the stairs. Once you hit the rock it will be thermal shut down. Ive seen it before.
11-05-2010, 12:13 AM | #10 |
Rock Crawler Join Date: Mar 2008 Location: Grand Rapids
when you burn it down i'll buy your axles cheap |
11-05-2010, 06:11 AM | #11 |
Rock Crawler Join Date: Nov 2009 Location: Southern, IN
11-05-2010, 03:05 PM | #12 |
Well guys I went to the creek today for a quick run. Man the xr10 can make some sick lines. I burned through 2 1500 3s packs to cutoff, and 1/2 of another 1500 pack. Mind you it was cold today, 2c, warmed up to 4c and theres water running on the creek (its up hill a fair amount not much water) Servo worked awesome. Never stalled out, I only worked it hard 1 time where it still did full travel but took a sec longer to get there. There was 1 time as well where I was high centered all 4 tires and the front tire was over the ledge and I steered the xr to the right and it lifted the whole crawler up 1/4 to 1/2 inch up and it was enough for the tires to bite and off I went up the ledge, so for me more then enough servo power. Esc's ran fine all day no higher then 3 on the led, and mostly colder then that. Oh yeah, I never had 1 glitch all day running 2 esc red power wires into the reciever. Butter smooth all day. Last edited by Darrell262; 11-05-2010 at 03:10 PM. Reason: Forgot something |
11-06-2010, 09:33 AM | #13 |
Just be careful man. I know someone that ran a FXR without a cc bec and a hitec 645 and his esc went up in smoke.
11-06-2010, 10:31 AM | #14 |
Will do. I am thinking. 2 esc's of the same brand, same model with the same firmware both setup exactly the same software wise running on the same battery should be very close to the same output for power from the bec in sync I am hoping. So, the 6v 3amp should be the same on both esc's or very close. So I am betting on both outputs to the receiver should make 6v, 6amp as both esc's would share the load of powering the servo. Thats my theroy. Also, up here where I live it doesnt get that hot anyhow not like in the states. So heat wise it is running good. Maybe down the road I'll just buy a 600 or 900 mah 2s lipo and run it to the receiver as my futaba R614FF is rated for 2s input 7.4v and the radio and servo together shouldn't take that much juice to run for the 3-6 hours I would run it before charging the battery |
11-06-2010, 10:52 AM | #15 | |
RCC Addict Join Date: Mar 2009 Location: Interior BC
1st bec i had from cc was shot and even customer service didnt know what the titan 12t was, they had me cut the red wire to my xl5 esc. DoH screw CC BEC | |
11-06-2010, 11:00 AM | #16 |
Sounds like the ppl that are having problems with the CC Bec are going to be the same ppl that wine and bitch when their gears or bearings fail. Thats just my opinion.
11-06-2010, 11:13 AM | #17 |
Quarry Creeper Join Date: Dec 2008 Location: Lansdale
Your nuts CCBEC FTW!!! |
11-06-2010, 11:18 AM | #18 |
I dont know how old my cc bec is. Its been in 3 or 4 different rigs, one being murderfaces. It is the community CC Bec. I have changed the voltage output on it, shortened the wires, and even soldered on the wires. I believe when murderface ran it he went in water with it and it isnt even waterproofed. Still doing good.
11-06-2010, 01:01 PM | #19 | |
11-06-2010, 01:43 PM | #20 |
Thats what I thought. That CC bec is a troop though.
