View Poll Results: Would you buy a straight Lunsford link for a xr steering conversion?? | |||
Yes I would buy a straight Lunsford link for a steering conversion!! | 91 | 79.82% | |
Bacon............... | 23 | 20.18% | |
Voters: 114. You may not vote on this poll |
11-09-2010, 01:02 PM | #21 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
Want. Will it work for HR knuckles?
11-09-2010, 01:41 PM | #22 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
Tried that too. You need to clock your motor too high with a straight link which puts your servo horn down lower in front - no way, I don't need that. And clocking your motor up that high raises your Center of Gravity - don't need that either That's why I made this link from 1/4 steel round stock. Chose steel so it won't gouge like aluminum. My measurement after bends is 147.5mm - bare link end to end (Not eye to eye) Measures 180mm eye to eye w/ bends and revo ends w/ V.P. Knuckles & Chubs Posted in tips and tricks - Axial XR10 Tips & Tricks Full Lock: Front shot: Last edited by Rig Rocker; 11-12-2010 at 09:47 AM. |
11-09-2010, 02:13 PM | #23 | |
RCC Addict Join Date: Jun 2008 Location: Nunya Idaho...
11-09-2010, 03:13 PM | #24 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
I like the bent link alot...I'm a bit confused about how short yours is??? Is 147.5mm before or after you bent it??
11-09-2010, 03:20 PM | #25 |
Rock Stacker Join Date: Sep 2007 Location: Lambertville
I'd be interested in one |
11-09-2010, 03:21 PM | #26 |
Heres mine (its rolled up in the pick then sits down inside while turning. If I remember (I can check later) mine was 5.75" before the threads. |
11-09-2010, 11:49 PM | #27 |
Quarry Creeper Join Date: Sep 2009 Location: Concord
i love bacon! titanium is nice too. but bacon gets my vote. maybe a link with longer threads and one side reverse threaded like a turnbuckle. and jato ends. just to keep it tunable.
11-10-2010, 01:25 AM | #28 |
Rock Stacker Join Date: Feb 2010 Location: Manila
I really want to do this mod for my XR. I'm worried about messing it up though because it is pretty much irreversible short of buying a new axle housing. Has there been any problems with the straight link hanging up on rocks? |
11-10-2010, 01:39 AM | #29 | |
Quarry Creeper Join Date: Jan 2010 Location: UAE in the GCC
they dont hang at all ... and if they do .... its not something the 45T's can't handle | |
11-10-2010, 08:39 AM | #30 |
the lunsford links are threaded like a turnbuckle so you could technically adjust it while on the vehicle...the only thing that would make it easier is if it had a hex to use a wrench on...but then "that might hang up on a rock"
11-10-2010, 12:29 PM | #31 | ||
(Not 100% reversible since you can buy a new housing) And no, it doesn't get hung up on the rocks. Thats why I used steel versus aluminum so it would slide over rocks versus gouging and dragging. Last edited by Rig Rocker; 11-10-2010 at 08:25 PM. | ||
11-10-2010, 05:50 PM | #32 |
Quarry Creeper Join Date: Dec 2008 Location: Lansdale
I tried a 140mm ti link from lunsfor with Jato ends and it is still a little short. I think 145mm would work if you keep it striaght and might need 150mm or longer if you want bends.
11-10-2010, 05:58 PM | #33 |
So I'm not sure why it hasn't been posted yet but the measurement eye to eye should be right at 177mm. Is that what you guys have?
11-10-2010, 08:21 PM | #34 |
Rock Crawler Join Date: Jul 2010 Location: VOLS!
Used traxxas revo toe links #5338 with jato rod ends and added a small bend and cut stock link slot off back of axle. |
11-10-2010, 08:22 PM | #35 | |
I changed the above post to 180mm with V.P. knucles and chubs and zero toe in Do you have stock knuckles and chubs Harvo? Last edited by Rig Rocker; 11-10-2010 at 08:25 PM. | |
11-10-2010, 08:26 PM | #36 |
Rock Crawler Join Date: May 2009 Location: Medford, Oregon
Bacon for sure! |
11-10-2010, 11:06 PM | #37 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
Lunsford 140mm link with 4mm jato ends fits great.
11-10-2010, 11:24 PM | #38 |
11-10-2010, 11:29 PM | #39 |
Lunford doesn't measure their links eye to eye they measure total length and give you an estimate of how much is threaded. The problem I have seen in pics with the 140mm link + jatos is it looks like there is very little thread engagement in the jato rod end and that is a severe weak link, I have popped a few jatos on my super with a lot of engagement and would be very worried to run that setup. I have a feeling a vendor here will be producing these soon though! |
11-11-2010, 12:47 AM | #40 | |
Then all you need is revo ends and your set !! I think a straight link would be best so you can still get FULL throw from your knuckles.. | |
