11-10-2010, 11:57 AM | #1 |
Quarry Creeper Join Date: Mar 2008 Location: Columbus OH
| Hot Racing upgrades ???
Has anyone bought any HR parts. Do the motor plates have tighter bearing tolerances than stock? I'm very curious to know how the gears are. And how is the fit with the transmission cover and any other parts such as knuckles etc. I ask because I have heard of issued in the past but I want to toughen up the xr asap. I'm looking for infomed reviews of XR parts not a bash fest. Thanx. |
11-10-2010, 12:19 PM | #2 |
I am running the gears. I broke a transfer gear when two stock sized bearings failed. Since upgrading the bearings to 9mm and replacing the gear, they have been rock solid. They make a clicking noise that sounds like a chewed bearing with stock and 9mm bearings, it concerned me at first, but I have grown to accept they are just noisy gears after much abuse. I am using mobile1 synthetic grease as gear lubrication. |
11-10-2010, 12:23 PM | #3 |
RCC Addict Join Date: Sep 2005 Location: Tempe, AZ
I haven't tried them but have only heard good things about the HR stuff for the XR. That being said...just do the 9mm mod on the axial plates and be done. I think the 8mm even in a good fitting trans plate will blow too early given how low the load bearing levels are compaired to seen loads.
11-10-2010, 12:27 PM | #4 | |
Keep Crawling in Crawling Join Date: Jan 2009 Location: Commerce City
11-10-2010, 12:28 PM | #5 |
I broke a transfer gear as well while running the stock bearings. I just installed an HR gear this morning and ran it for a half hour or so with 10mm bearings in the motor plate and everything was working really good. No abnormal noises from mine, but I'm not running the entire set...yet. I was hoping someone would come up with 300 gears or an equivalent.
11-10-2010, 12:51 PM | #6 | |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
VP is working on their version of the gears and I'm sure they'll be as tough as super 300 | |
11-10-2010, 01:01 PM | #7 |
RCC Addict Join Date: May 2008 Location: On the rocks
Either wait for a few more days till VP release or even AXIAL when they release some of their option parts. idk though, I keep hearing "be out soon" for the past 3+months so who knows the release. tbh I don't use the HR anymore. just my personal pref but I just get more damage than benifit with my exp. just my honest opinion though. gl. |
11-10-2010, 01:25 PM | #8 |
RCC Addict Join Date: Nov 2009 Location: Tulsa
I've never had any problems with there parts
11-10-2010, 01:52 PM | #9 |
When replacing gears...Just replacing one is like just replacing one brake pad on your car. It will get you buy, but isn't a good idea. Or put new Rotors on your car but not changing your Pads. When installing the HR Gears. Either do the 9mm upgrade or Bushings from VP. 1. They way I look at it. Just replacing one Gear with a HR. If an old gear breaks your just going to damage your New gear when it chews up broken stock one. 2. If you just upgrade the gears and not the Bearings. You put you new gears at risk again. A Stock Bearing Fails and your HR will jam up under 3 Cell Lipo Power. I highly suggest when doing a Gear upgrade. Do them all and the bearings at the same time. If not it's just a Bandaid.... I'm not stating this b/c I think HR's Gears are weak and won't hold up, but the Transfer gear is small. I think of the gears as an invest and they should be protected. Last edited by run2jeepn; 11-10-2010 at 01:54 PM. |
11-10-2010, 02:04 PM | #10 |
Newbie Join Date: Dec 2009 Location: Tucson
I just got done installing the HR motor plate and transmission cover along with the Boca Bearings. Kept the stock Axial gears (third set). The fit of the bearings in the case was excellent. Haven't really bashed the rig yet so we shall see.
11-10-2010, 02:10 PM | #11 | |
The time I broke the transfer gear I was being stupid with the throttle slamming forward\reverse on textured concrete for some stress testing and killed two bearings causing the gears to slam together. Not the gears fault. Since upgrading to 9mm as I posted above things have been rock solid, even through my stress tests Thanks for having these on your site In the end they may not be the best option out there, but for now they are the only machined gear option, and well worth it in my opinion. I now trust the rig to power through a bind, smack the throttle hard from a stop to jump gaps, and slam reverse to save before the rig falls backwards off of steep climbs I did not find the right line for. Last edited by DickyT; 11-10-2010 at 02:12 PM. | |
11-10-2010, 02:58 PM | #12 |
Quarry Creeper Join Date: Jun 2008 Location: Portsmouth UK
Im running full HR gears with 9mm bearings in the motor plates and 5x8 bushings in the cases. No problems so far |
11-10-2010, 03:37 PM | #13 | |
That wasn't really aimed at anyone.. I'm waiting on VP to release there Gear Case upgrade before I finish my billed. I know of one other Company that has a Gear Case upgrade with 10mm Bearings.... | |
11-10-2010, 05:25 PM | #14 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
I am running full HR gears and 8mm AVID bearings in both of my XR cases. So far I have had no problems. I have three comps and lots of carpet abuse and practice on them so far. I pulled the cases apart to see how much wear they had last week before my comp, and they look as good as new. Just as soon as the complete 9mm upgrade kits are available, I will have those installed. If you need a complete set of HR gears, PM me. I have a full extra set, spools and all. I thought I was going to need them for the future, but at this point I know I won't. |
11-10-2010, 07:15 PM | #15 |
I'm off to buy a 9mm reamer in the morning. I've got the avid flanged bearings, but I'll have to risk stock in the case for now unless I can find a traxxas replacement in town/ Comping sunday. I just hate leaving everything to chance while I wait for VP to release stuff, and even then I don't know that I could afford all of their stuff.
11-10-2010, 07:48 PM | #16 | |
and who? when? I will still probably go VP, I have so much other vp on the rig it would be a shame to break character. | |
