11-21-2010, 02:44 PM | #1 |
Quarry Creeper Join Date: Mar 2008 Location: N. Ridgeville , Ohio
| vnXR10 "UPDATED" Mantis vnXR10 Won this at the Nats (thanks rockcandyrcc ) and finally am posting pics . Specs: Sidewinder esc Punk dig jr 9100t servo with losi aluminum servo horn Castle creations BEC Spektrum DX3 with sr3000 RX Thunder power 850mah 3 cell li-po 45c or Common sense 850mah 3 cell li-po 30c Integy 45 turn motors 15 tooth pinion front, 13 tooth pinion rear electronics/battery tray made from old dettatchable radio face case T1E high clearance rear links stock lower rears moved to front lowers homemeade solid aluminum 30 degree bent uppers front & rear homemade 1 piece steering link (stock front lowers) servo flipped for just a little more clearance homemade extended delrin rear upper shock mounts (front & rear shock mounts on outside of chassis) homemade aluminum steering arm upper braces 2mm 's wider V ing the chassis from top to bottom Chromed Mayhem comp dbl phatty's aluminum fronts, delrin rears Hot Bodies white dot Sedona's with stock rover foams front and f400 rear foams or Stock XR10 beadlocks with set screw weights Hot Bodies white dot Rovers with stock rover foams front and f400 rear foams 5hr energy drink bottle motor protectors Rig rtr weighs 5 lbs 13 ozs Last edited by vn1500; 11-14-2011 at 03:13 PM. |
11-21-2010, 03:28 PM | #2 |
Rock Crawler Join Date: Feb 2009 Location: LaGrange
truck looks siiiick... i really like the rear upper shock mount
11-21-2010, 03:28 PM | #3 |
11-21-2010, 03:37 PM | #4 |
Nice rig Tom, how is it working for you now?
11-21-2010, 04:35 PM | #5 |
| Works AMAZING works so well i've (with a tear in my eye) retired the 2.2 Berg The XR10 just fits my style of driving better than my Berg did . I was 40+ packs deep into this truck before i had my first stock bearing failure (mustangboy,nitrojeff,& justjerry can bear witness) the truck , stock bearings and all will take some PUNISHMENT !!!! Stock bearings would've lasted longer , but the last predicament i put it into was completely driver jackassedness that killed the bearing thus takin 4 teeth off the transfer gear .
11-21-2010, 04:57 PM | #6 |
Quarry Creeper Join Date: Mar 2008 Location: Columbus OH
Tom, Did you have to mod anything or do the T1E rear lowers and stock rears moved to the front leave you at 12.5 wheelbase? |
11-21-2010, 05:04 PM | #7 |
| Radio plate is kicked up a little in the rear too clear the links thru articulation range. Used all the stock long bent ends (drilled & tapped for 4mm hardware), puts it just under 12.5" at full droop. Rear upper links are 129mm eye to eye to clock the rear motor up & the extended rear shock mounts keep the shocks from touching the lower links & still give me a 3.5" belly clearance at the back of the skid. Last edited by vn1500; 11-21-2010 at 05:08 PM. |
11-22-2010, 07:11 AM | #8 |
Rock Stacker Join Date: Oct 2009 Location: ky
thats nice,what a prize that would be |
11-22-2010, 05:44 PM | #9 |
12-11-2010, 06:25 PM | #10 |
| Little update to the vnXR10 Thanks JPcustoms !!! Thanks mustangboy_347 HR aluminum C's HR aluminum knuckles HR aluminum lock outs HR aluminum trans housings x2 VP bushings for trans x2 and threw in a couple of FRESH integy 55 turn motors 15 tooth front pinion 13 tooth rear pinion. narrowed sedona's in the rear (thanks just jerry aka bullfrog) |
12-11-2010, 06:39 PM | #11 |
Rock Crawler Join Date: Dec 2005 Location: Connellsville PA."fayettenam" lol
Nice added bling! |
12-11-2010, 06:55 PM | #12 |
Rock Crawler Join Date: Aug 2008 Location: Wine Country
Did ya beef up the rear? I know when I had issues with my rear stuff they asked if I had the rear servo mount on couse it would cause twisting in the rear if it wasn't there. besides that little note looks nice.
12-11-2010, 07:04 PM | #13 |
| Thanks brada Well aint that somethin . I'll be puttin that plate back on then . Thanks for the heads up . |
12-11-2010, 07:18 PM | #14 |
Glad to see your wares finaly showed up |
12-11-2010, 07:36 PM | #15 |
| Thanks Bob, i'm freakin glad too , and thanks for helpin me out with gears I now freakin have 2 of every-damn-thing in my pit box hahahahaha On a side note just came in from the garage (installin that damn rear servo plate) hahahahahahahahaha |
12-11-2010, 07:44 PM | #16 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
Very nice, how are the HR trannys? Some say with the VP bushings they get hot.
12-11-2010, 07:54 PM | #17 | |
Haven't really had it compin on the rocks yet , headin to Columbus compin tomorrow so i'll have a better guage of them then . Spoolin them up with a drill (where as my 55 turns will never get them spinnin that fast) and just runnin 5 minutes of messin around on my practice course didn't have any real heat issues. but i'll definitely keep my fingers crossed hahahahaha | |
12-11-2010, 08:58 PM | #18 |
Alright, keep us posted on how everything works. |
12-12-2010, 04:32 PM | #19 |
| The HR upgrades worked AWESOME !!! No complaints what so ever ... We ran 3 courses 10 gates 6 minutes and even with a couple of on my lid full throttle forward-reverse whacks of the throttle , no heat issues in the tranny housings with VP bushings in them . Thanks HOT-RACING Thanks Vanquish Products Thanks JP customs On a side note when i first built the XR-10 i put rovers on it then i switched to sedonas , today for the 2nd course i tried the rovers again and i will probably never put them on the XR-10 ever again . The sedonas just work their a$$e$ off with the way the truck is set-up .. |
12-12-2010, 04:42 PM | #20 |
RCC Addict Join Date: Nov 2008 Location: I don't think theres rocks in Florida
