12-24-2010, 08:20 PM | #1 |
Rock Crawler Join Date: Apr 2010 Location: Kelowna, B.C., Canada
| ax-10 crazy turned xr-10 crazy
Since the xr-10 was released it was something I wanted but didn't think I could afford, so I started to save some $, sold my crawler and Stampede and invested it into a new crawler. So far I have for electronics: -Futaba 4pl -Hitec 7980 servo -Dual hh brxl's -40t brood handwound motors -cc bec -4s lipo For upgrades I have: -Front and rear Vanquish motor plates -hr gears in the rear with an axial machined final gear for less weight -rc4wd gear set in the front for more weight -Vanquish knuckles -Robitronics servo arm -Axial aluminum 30* bend upper links -Traxxas bushing to replace all 5x8 bearings in both transmissions -hb rovers siped -black axial springs front and rear Thanks Last edited by ax-10 crazy; 06-14-2011 at 06:32 PM. |
12-24-2010, 08:39 PM | #2 |
Rock Crawler Join Date: Mar 2008 Location: Grand Rapids
lookin good so far ,looks like you need to vent those tires though
12-24-2010, 08:46 PM | #3 |
12-24-2010, 08:58 PM | #4 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
Looks good, while your waiting to get more parts it will give you time to read up on some easy mods and get those done. I did the steering mod, narrowed my stock wheels down to 1", made a motor skid, siped my Rovers, and added some longer rod ends to my rear upper links to tuck the motor up for more clearance. while I waited for parts Last edited by BLKXJ 96; 12-24-2010 at 10:04 PM. |
12-24-2010, 09:06 PM | #5 | |
12-24-2010, 09:17 PM | #6 |
| I agree, I did the steering mod because I heard of a few guys burning up there servos with the stock steering setup, and it's real easy. I cut the wheels down because I was board |
12-24-2010, 09:36 PM | #7 |
| My current solution to the steering Problem is going to be running over 600 oz. Of steering power. |
12-24-2010, 10:00 PM | #8 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
The steering problem isent the torque at all. The problem is something else. One thing to think about is the stock bearings, we know they suck and that they are going to go out soon. Be careful, you dont want to wait for Axial to send you a set of new gears. I did the 9mil mod, still lunched a bearing. I was lucky, stock gears chewed them up and didn't break. Some ppl arent that lucky. I put a new 9mil in there, but VP plates and cases are on the way with some brOOd 35t R/T motors I hope that the rig holds up for you in stock form, its a great truck stock. I just got sick of being careful with it and as soon as I went crazy a 9mil fails. Oh well, thats my .02. The rig looks good man |
12-24-2010, 10:15 PM | #9 |
X2 on the stock bearings, I didn't even put mine in they are still in the bag...I hope thy work on my Slash hubs. I have been running VP bushings from the start and had no problems yet. I've wound the thing up pretty good a few times on my home indoor course, I try to be smart-ish and not over do it. I run a 7950 with the steering mod for about twenty to thirty minutes stright at stock voltage and the servo isn't even warm. |
12-24-2010, 10:23 PM | #10 | |
12-24-2010, 11:07 PM | #11 | |
12-24-2010, 11:11 PM | #12 |
What are some good replacement screws for the stock beadlocks? Preferably sone with a bigger hex size. Probably 3 out of 6 screws per beadlock ate now partially stripped, and my good hex wrenches are still backordered. |
12-25-2010, 12:24 AM | #13 |
Rock Crawler Join Date: Apr 2006 Location: Folsom, CA
| I ordered a pack of 100 M3x25mm countersunk stainless allen head screws from McMaster for like 12 bucks shipped. I was planning to drill out the holes in the wheels and countersink the holes in the beadlock rings more to accommodate the bigger head on the screw but ended up ordering VP wheels instead Only issue I saw with the M3 screws was more threads means you'll be turning them a lot more with the allen wrench. I agree though, the stock screws suck ass!
12-25-2010, 02:34 PM | #14 | |
Thanks | |
12-25-2010, 03:13 PM | #15 |
12-25-2010, 03:21 PM | #16 | |
I got 1 inch because my stock wheels are narrowed, 1.25 if you are running full width wheels. I think I paid about $3 bucks for 24 of them. | |
12-25-2010, 03:28 PM | #17 | |
| Quote: | |
12-25-2010, 03:29 PM | #18 | |
12-25-2010, 04:34 PM | #19 |
| I bought countersunk screws, not button heads. You use an allen key to tighten them still, just like the stock stuff. Type this part number into McMaster- 92125A138 . They probably don't need to be that long though, I just ordered 25mm screws since the cheap stock ones are that length.
12-25-2010, 06:44 PM | #20 | |
