Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: VP Hub sizes
Old 02-26-2011, 11:57 AM   #1
zjguy721's Avatar
Default VP Hub sizes
What sizes are people running in general, or what would be a "stock" size? I'll probably be running 1" wheels and Sedonas or Boss Claws.
zjguy721 is offline   Reply With Quote
Old 02-26-2011, 12:22 PM   #2
abadk9420's Avatar
I don't runn either of the tires but I am sure I could, but with Rovers on DH2's up front I run a 585 hub with one spacer removed from the wheel, and in the rear I run a 1" SLW V4's with a 350 hub, I might go to a 460 hub though.
abadk9420 is offline   Reply With Quote
Old 02-26-2011, 12:28 PM   #3
Good thread. I am running Dh1's front and rear w/ sedonas. I want narrow!! What hubs should I get for them?
calikingcrawler is offline   Reply With Quote
Old 02-26-2011, 12:48 PM   #4
On the DH 1's the 335's are about the same as stock, in the rear on DH's you could run the narrowest SLW hub to slim up some.
On SLW's 600's are about stock with the 475 being a little slimmer than stock. Seems most with SLW F/R tend to hun narrower hubs (350F/225R).
I run DH's with 335 on front and SLW's with 600 rear and plan on switching to 475's on back.
indiana mudcat is offline   Reply With Quote
Old 02-26-2011, 01:14 PM   #5
losiking1's Avatar
I'm running 475's on the front and 600's on the rear. I also have Losi hexes and rear width is 10 3/4 " front is right on 11". Hope this helps. Also gained a little more steering. Tires (sedonas) barely touch shocks at full lock
losiking1 is offline   Reply With Quote
Old 02-26-2011, 01:14 PM   #6
slw's
front .350
rear .225
klabeaume is offline   Reply With Quote
Old 02-26-2011, 01:58 PM   #7
SLW all around
350 front
475 rear
remember.... narrower = less room for knuckle weights..
BurnLatex is offline   Reply With Quote
Old 02-26-2011, 02:02 PM   #8
DHII's with 585's front and back. Right around stock width.
articzap is offline   Reply With Quote
Old 02-26-2011, 02:12 PM   #9
If you plan to run d-lux knuckle weights then you will need 350-475....and more like 475's then 350's...
53 willys is offline   Reply With Quote
Old 02-26-2011, 08:49 PM   #10
common combos in colorado that i see is 335's with dh1's or 460's for dh2's up front and slws with 475's out back
flapjack is offline   Reply With Quote
Old 02-26-2011, 09:12 PM   #11
i run 350 front 475 rear on .7 v3s front width is about 11.25 out to out and rear 10 7/8 out to out
murderface is offline   Reply With Quote
Old 02-26-2011, 09:51 PM   #12
All depends on the wheels as to what hubs, I like the DH wheels because you can weight up or down as you like with out ripping down the wheels. For the rocks your gonna run here in Michigan, Sedonas and Rovers work great, Boss claws were the hype over the summer but that faded fast. Most of those guys switched back to Sedonas, seems to be a good choice for the indoor and outdoor courses.
The stock wheels can also be narrowed to 1" very easy, check my Albums. After you do this you can run the stock wheels with the VP knuckles.
http://www.rccrawler.com/forum/album...id=1510&page=2
BLKXJ 96 is offline   Reply With Quote
Old 02-26-2011, 10:25 PM   #13
I'm running DH 2's w/ 460's up front at 1" wide and v4's w/ 475's in rear at 1" wide. Front track width is 11 1/4" and rear is 10 3/8". Running sedonas with 5.5" C.I. double douces uncut front and rear.
Later,
Farmer
Farmer is offline   Reply With Quote
Old 02-27-2011, 01:41 PM   #14
SLWs and .225s all 4 corners.
dragrcr is offline   Reply With Quote
Old 02-27-2011, 02:01 PM   #15
X2, Pretty narrow in the back but seems to work for me so far.
T-buck is offline   Reply With Quote
Old 02-27-2011, 02:30 PM   #16
--------------VP hubs------width F-----VP Hub------width R
Stock Wheels-----------------11.0--------------------10.2
DH II----------335hub---------11.0----- 460hub-------10.5
DH II----------585hub---------11.5------------------------
SLW v2---------------------------------600hub--------11.1
SLW v3 -------350hub---------11.2------------------------
SLW v3 -------225hub---------10.8----- 225hub---------9.9
-----------------------------------------350hub-------10.25
This info was collected by reading posts by others.
KBrog is offline   Reply With Quote
Old 02-27-2011, 11:20 PM   #17
Originally Posted by klabeaume View Post
slw's
front .350
rear .225
Your avatars....
eddiepfund is offline   Reply With Quote
