03-03-2011, 06:53 PM | #1 |
RCC Addict Join Date: Jul 2009 Location: Shreveport, LA
| TC's CDW Chump RT build/re-build REBUILD starts on Page 4: post 72 Heres the run down:UPDATE: CDW Chump RT w/ custom bent Ti links VP Axles: Axial bottoms, shafts, and hexes RC4WD gears Front Axial HD gears Rear with boost mod below the main gear bearings Axial SCX-10 aluminum shocks Holmes Hobbies Hand Wound Pro 45Ts Rowdy Racing Battery tray and ESC motor mounted tray Dual Castle Creations Micro Mamba Pros decased and heatshrinked together Hitec 7950TH wired directly to CC BEC w/ Crawler Innovation's servo guard Chaotic Crawlers Bent Ti tie rod Tires are assorted on VP SLWs 450 & 500mah 3 cell Lipos __________________________________________________ _______________ XR-10 Axles T1E Forward bias chassis VP Cases & Motor Plates Axial Machined Gears rear, Stock front, Titanium shafts F/R VP Knuckles Chaotic Crawlers Drag link VP DH II's up front with 4 slugs VP SLW V3s Rear Big Bores with CO shock caps, mini T springs, and Dr. Franks retainers Castle Creations Micro Sidewinders w/ BEC on a 4PL Holmes Hobbies HW Pro 45T's Big thanks to Helhedded, Dr. Frank, and Rootar for answering all of my questions, and general guidance! Last edited by TC09mini; 04-10-2012 at 01:16 PM. |
03-03-2011, 07:02 PM | #2 |
Rock Crawler Join Date: Mar 2010 Location: Hampton
i really like the look of the new T1E chassis. Nice build so far.
03-03-2011, 07:10 PM | #3 |
Rear Gears Front End Dr. Frank's Spring retainers MmmmmMMMMmmmmm Caster. . . yummmmm And for dessert steering And the tail Stance Last edited by TC09mini; 03-03-2011 at 07:12 PM. |
03-03-2011, 07:22 PM | #4 |
RCC Addict Join Date: Aug 2008 Location: Charlotte, NC
Looks good! Good choice on the chassis!
03-03-2011, 07:48 PM | #5 |
Newbie Join Date: Feb 2011 Location: Piscataway
I love the forward bias chassis......such an awesome looking rig. Why are some of you guys going to the short course springs? are there benefits? srry if i thread jacked
03-03-2011, 07:57 PM | #6 | |
Thanks, I think I've finally got a winner! The benefit is mostly for the front end. Less spring to tire rub than with the full size spring. On some shocks, especially on LCC shocks I used to run, the limiter would move. That being said, a little locktite could have fixed that. | |
03-04-2011, 05:27 AM | #7 |
Rock Crawler Join Date: Feb 2010 Location: Chapin, South Carolina
Action shots?
03-04-2011, 08:02 AM | #8 |
Quarry Creeper Join Date: Dec 2010 Location: Princeton Mass
Looks awesome, I'll be following your build closely I just got the t1e rockshow and have a few setup questions and some of your pics have helped. Are you using the stock upper front links and rear stock lower links for the rear uppers and what rod ends did you use for the t1e lower links. Thanks
03-04-2011, 04:34 PM | #9 | |
| Hopefully after this weekend I'll have some action shots for you. I'm Waiting on some new batteries so I don't fry my sidewinder micros. Quote:
03-04-2011, 06:12 PM | #10 |
Do it...the Ti is super easy to work with!
03-05-2011, 07:42 PM | #11 |
03-05-2011, 08:13 PM | #12 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
Looks good Get some practice with it before next months comp.
03-05-2011, 08:14 PM | #13 |
Pebble Pounder Join Date: Jan 2011 Location: Escalon Ca
Im not a fan of the moonbuggy but that looks pretty sweet!
03-05-2011, 08:41 PM | #14 |
Quarry Creeper Join Date: Mar 2010 Location: Central NC
Looks great. Can't go wrong with a T1E chassis. |
03-11-2011, 08:59 AM | #15 |
Thanks for all of the comments. Sorry I don't have any action pics for you. I'm still having some electronics issues. My CC micro sidewinders are really starting to tick me off. The rear works fine, the front esc after going in reverse doesn't always want to engage going forward and causes what essentially looks like a rear dig. Anyone have any suggestions on how to fix this? I understand that a few people have had issues with these ESC's. Is anyone else having this issue? |
03-12-2011, 06:05 AM | #16 | |
Pebble Pounder Join Date: Mar 2007 Location: Perkasie PA & Port Norris NJ.
03-12-2011, 12:04 PM | #17 |
Updates: Electronics: I'm sure this has been posted before but anyone running Castle Creations ESCs with a Futaba radio needs to reverse the throttle on the radio and calibrate individually. This seems to have cleared up 99% of my reversing issues. Now that green is forward and red is reverse, everything is running much smoother. No hammer needed. Wheels/Tires: The little that I have had this running, I noticed that I needed a bit more weight up front and some tire support. I ordered up some of Eddie at Crawler Innovation's weights and DHII's wheel rings. I ordered them on Friday night and in 1hr, they were shipped! INCREDIBLE service! I was getting a ton of wheel wrap and these should help! I halved the inner foam to fit the support rings I'll post up some additional action shots and reviews of the rings. I'm sure they are going to do just what I needed. Last edited by TC09mini; 03-12-2011 at 12:07 PM. |
03-17-2011, 12:13 AM | #18 |
RCC Addict Join Date: Jan 2010 Location: Lafayette
Looks good, glad you got it together. What hubs did you go with? I know a place you can come get some practice in this Saturday. |
03-17-2011, 11:03 AM | #19 |
Rock Crawler Join Date: May 2010 Location: San Antonio, TX
This is a really nice build. That chassis is looking better by the minute! Please post some videos when you get some driving time. Last edited by Oso787; 06-14-2011 at 07:48 AM. |
03-27-2011, 10:29 AM | #20 |
Finally had some time to get out and do some running with this truck. I'm experiencing a bit more of a learning curve coming from shafty than I expected. I just need to get more time behind the radio with this rig. Next changes, I've got some skidz made for the motor and I'm going to shorten the front lowers a bit. The front motor seems to be taking a real beating so I'm going to add caster a different way. Last edited by TC09mini; 03-27-2011 at 11:34 AM. |
Tags |
cdw |
