03-08-2011, 03:32 PM | #1 |
Pebble Pounder Join Date: Jul 2008 Location: Grand Island (middle of Nebraska)
| XR10 Viper Issues? or am I just fine
Ok to start this out, Something just doesnt seem right with my build so far... I cannot place the shocks directly over the top of the links in the front side, when the chassis rotates its almost like they bind in that area of articulation. So Ive moved the shocks to the outboard position, now is this going to be ok? or will some issue arise from this? Now Ive looked at everyones posted Viper on the XR10 forums, but I dont see the same issue that makes me scratch my head, from the side view I would think that the front end doesnt get as much suspension play as the rear, while Im green to this crawling...something just screams "STOP" but maybe Im being a bit over dramatic and nothing is wrong....but any input that I can get would only help me out! Side View while at rest on a surface: Side View with no force pushing of hindering the chassis in any way: The rear of the crawler seems just peachy, and works nicely.....the shocks are also outboard as well. From the front of the vehicle: To me the front end, seems to point down too much, but maybe thats suppose to be that way....*shrugs* or maybe its not..any advice so far guys both crawling wise, or people with the knowledge of Viper chassis would greatly be appreciated! Smoke |
03-08-2011, 03:37 PM | #2 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
You can keep the front shocks in the stock location. Its the rears only that need to be farther out on the shock mounts. Also put smaller rodends on your upper links.
03-08-2011, 03:40 PM | #3 |
Quarry Creeper Join Date: Aug 2009 Location: Phoenix
I don't run a Viper but I can give you a start. I started with those links on my XR until I switched to BWD parts. The front links at the axle, either turn them 180 so the bend goes up or use the stock straight ends. The rear at the axle should use the same larger bent ends like at the chassis as well. The small ends on the rear (at the axle) belong on the upper links at both ends. Now this may need to vary depending on length to get 12.5" and just turning the ends a turn tighter often helps if a touch long. |
03-08-2011, 03:40 PM | #4 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
Front uppers are to long. Shorter ones should fix the whole deal.
03-08-2011, 03:50 PM | #5 |
Quarry Creeper Join Date: Dec 2010 Location: Princeton Mass
Someone can correct me if im wrong but where he has put his shocks out board on the axles shouldn't you put a longer bolt all the way through and put a spacer in the middle of the 2 ears for strength. That's is how I outboarded my rear LCC shocks with alum spacers.
03-08-2011, 03:50 PM | #6 | ||
I can do the small rod ends on the uppers no problem, thanks for that! (just need to switch out the ones on the chassis side, those were the only long ones) Quote:
03-08-2011, 03:54 PM | #7 | ||
6mm x 101mm with a 30 degree bend, Im half tempted to figure out how long (if someone can answer this would save me time) and cut off a small portion and re-drill and tap that end so I wont need different links. Quote:
03-08-2011, 03:57 PM | #8 |
The binding in the front is probably the lower links because the axle is on such a clocked forward angle. If you shorten the front uppers you can put the shocks back in their stock location Had the same issue.
03-08-2011, 03:59 PM | #9 | |
Question is, how much do I need to trim off the 101mm to get the proper length? Last edited by Darth Smoke; 03-08-2011 at 04:05 PM. | |
03-08-2011, 04:04 PM | #10 |
Those upper bent links are fine in length, it is the wrong ends causing the problem. And yes, you have the front clocked way to far forward. The farther to the back the better... |
03-08-2011, 04:06 PM | #11 |
Yes the end are the reason why the links are too long. As stated prior.
03-08-2011, 04:08 PM | #12 |
Rock Crawler Join Date: Mar 2009 Location: houston
i had the same prob with upper links being too long.i cut 5mm off the chassis side of the links and its still a little too long.prolly be better to cut about 7mm off.now would be a good time to tap to 4mm or 8/32 also,hope this helps!
03-08-2011, 04:13 PM | #13 |
Ok, I will try the shorter links on the front and rear uppers to see if that helps (probably will..since 99% of you have more experience with these than I do) If that doesn't, I will go the route of taking off 7mm...and re-tapping them. |
03-08-2011, 04:15 PM | #14 |
Are the shocks stock? if so they are too long. The Viper was designed around a 4" eye to eye shock. If you have not limited them, internally limit them to 4" eye to eye. As stated above, the front upper links are too long. If you cut it to where the axial logo begins and use the rear most set of holes it will work or cut shorter for more forward holes. Your choice of rear shock placement is not ideal either. Lay them a few clicks down A warning on how you have those rear shocks mounted... The axles are a nylon polymer, that may not hold up too well unsupported from the other side. |
03-08-2011, 04:21 PM | #15 | |
So the rear shock bracket needs to come down to the third hole? Right now I went with the stock hole that someone suggested in a set-up viper chassis thread...someplace around this forum | |
03-08-2011, 04:26 PM | #16 |
Your rodends at the front axle are pointing down also. Rotate them 180
03-08-2011, 04:34 PM | #17 | |
I use the second from the bottom hole on the rear and the second from the top up front. Use the shortest rod ends if not already, then internally limit the shocks to 4", shorten the front upper link and things should smooth out for you a lot | |
03-08-2011, 04:38 PM | #18 | |
Awesome, thanks for all the info everyone!!! | |
03-08-2011, 04:58 PM | #19 |
I'd use a longer front lower to get some length back at the same time as rotating the axle back. You need to go until the C's lean back instead of way foward the way they do now. |
03-08-2011, 06:02 PM | #20 |
Ok so I went through things that have been suggested and here is what I have atm. Front Upper Links: 101mm Both rod ends are short/curved Front Lower Links: 101mm Both rod ends are long/curved Rear Upper Links: 101mm Both rod ends are short/curved Rear Lower Links: 101mm Both rod ends are long/curved Front Shocks: Centered in between the ends (no binding now) Rear Shocks: Centered in between the ends (no binding) Rear shock mounts on Viper Chassis: 2nd hole from the bottom Front shock mounts on Viper Chassis: 2nd hole from the top [Still need to limit the shocks, that will be later one when I want the messy cleanup] Length: went from 12.125 to 12.50 Pics: What I have changed from your suggestions, drastically improved the function and look! Not sure if I should trim something or just leave it...Any further suggestions? |
