03-11-2011, 06:46 PM | #1 |
Pebble Pounder Join Date: Jan 2011 Location: vienna
| replacing bearings and Incision XR-10 Axle Transmision Case
If I want to replace the bearings on my stock xr10 and upgrade the transmission case. Can I just buy the Incision XR-10 Axle Transmision Case and that will do it? Or should I get the XR-10 Transmision Bronze Bearing kit (7pc.) in addition to the Incision XR-10 Axle Transmision Case? I'm planning on ipgrading to the Incision XR-10 Axle Transmision Case. But while I'm at it I think I want to replace my bearings too. Can someone explain? Thanks |
03-11-2011, 06:48 PM | #2 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
read much? http://www.vanquishproducts.com/vanq...sion-ca10.html PRODUCT DETAILS •3ea. 5mm x 10mm x 4mm precision sealed ball bearing. the cases and plates come with the bearings. if you're going with the cases, defenatly get the plates too. that will take car of the bearings on the otherside of the gearbox (you will still be left with 8mm bearing on the transfer gear) |
03-11-2011, 06:53 PM | #3 |
Read what? lol Yeah I saw that transmission case comes with: •3ea. 5mm x 10mm x 4mm precision sealed ball bearing. •1ea. M3x.5 SHCS x 10mm •3ea. M3x.5 SHCS x 20mm •2ea. M3x.5 BHCS x 12mm but the XR-10 Transmision Bronze Bearing kit (7pc.) upgrade has different bearing size: 4 ea. 5mm x 8mm non flanged bearing (bushing) 3 ea. 5mm x 8mm flanged bearing (bushing) to be honest I have no clue what the XR-10 Transmision Bronze Bearing kit (7pc.) upgrade suppose to replace (assuming its for the transfer gear?) If thats the case I'll upgrade it too Last edited by bikeboy; 03-11-2011 at 06:56 PM. |
03-11-2011, 06:57 PM | #4 |
bronze bearings (bushings) replace the stock sized 8mm bearings. the VP plates and cases bring the bearing size up to a size that generaly doesn't eat itself. (quality boca bearings to boot too) I personaly run VP motor plates and traxxas bellcrank bushings in place of all the 8mm bearings. I have killed 2 gears in my rear axle, and have HD gears coming, aswell as aluminum gear boxes' (unfortunatly not VP, so I will continue to run my traxxas bushings) Last edited by fred0000; 03-11-2011 at 07:02 PM. |
03-11-2011, 07:00 PM | #5 |
ok than, thats settle it going to have to drop another $170.00 to the crawler. upgrade for VP Case, VP bearings, and VP plate the XR-10 Transmision Bronze Bearing kit (7pc.) is a boco bearings? |
03-11-2011, 07:02 PM | #6 | |
the case come with bearings the plate come with bearings Last edited by fred0000; 03-11-2011 at 07:08 PM. | |
03-11-2011, 07:07 PM | #7 |
thats what i want to hear - notice the Newbie as my title. Maybe it need to change to "Don't read much" But really, I'm a noob just wasn't sure - but you save me $50.00 bucks (was going to buy 2 of them) - guess that money goes to reading glasses |
03-11-2011, 07:10 PM | #8 |
wow.... ok sorry, I removed the "s"'s from the backs of a couple words in my last post. seems I have comfused you once again. you will need 2 cases, and 2 motor plates if you want to do front and rear axle they are not sold in pairs. |
03-11-2011, 07:23 PM | #9 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
Fred is correct in every way. I'll make a list for you, so you can get the right parts for the upgrade. 1. 2x VP trans cases 39.99x2= 79.98 2. 2x VP motorplates 19.99x2= 39.98 That is all you need, nothing more, nothing less. Thats a grand total of 119.96, that dosent include shipping. I hope that helps and sums up the whole question you have. Oh, also the bronze bearing kit is for those who dont want to dish out the money for the cases and plate. They are just for the stock cases and plates. Last edited by Jeepkid; 03-11-2011 at 07:41 PM. |
03-11-2011, 08:58 PM | #10 |
Quarry Creeper Join Date: Feb 2008 Location: Plano. Il
Throw those glasses on when you order and you can get yourself a free VP t-shirt too.
03-11-2011, 09:52 PM | #11 |
Quarry Creeper Join Date: Dec 2010 Location: Princeton Mass
Only if you give them you Ser# to your rig or no t-shirt. Took me the second order and a call to get it.
03-11-2011, 10:15 PM | #12 |
ok that sums it up and explaining the bronze bearing kit already got the t-shirt :-) thanks for your help |
03-11-2011, 10:41 PM | #13 |
Not a problem. If you feel you got a stupid question, feel free toPM me and I may be able to help you out. As long as you can read it |
08-31-2012, 08:41 PM | #14 |
Rock Crawler Join Date: May 2007 Location: Salt Lake City
| Re: replacing bearings and Incision XR-10 Axle Transmision Case
Lol that's funny shiz rite there! I run just the motor plates and my 5x8x2.5 bearings on the Gearshaft went out and took out the gears. Dam cheap axial bearings. Time to upgrade.
Tags |
bearing, xr10 |
