Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: XR10 motor skids courtesy of Walgreens...
Old 05-01-2011, 07:45 PM   #1
jwr
Default XR10 motor skids courtesy of Walgreens...
and a couple minutes on the bandsaw:
1" diameter container snap fits into place although I might hit one end with a thin strip of servo tape.
jwr is offline   Reply With Quote
Old 05-01-2011, 08:54 PM   #2
Nice, thanks for the tip.
I just went and made a set from similar material.
Norcal_GIT_r is offline   Reply With Quote
Old 05-02-2011, 06:06 AM   #3
I do the same thing on my motors.
ROWDY RACING is offline   Reply With Quote
Old 05-02-2011, 06:27 AM   #4
Couple of minutes on the bandsaw? You need to change your blade
Good job bro, I use 5hr energy bottles
SACCO is offline   Reply With Quote
Old 05-02-2011, 07:23 AM   #5
Nice...just what I needed...a little more orange to replace the white skids I have now...THANKS!
ittybitty is offline   Reply With Quote
Old 05-02-2011, 07:23 AM   #6
They look good, though you may want to extend it out a little further to protect the endbell
DickyT is offline   Reply With Quote
Old 05-02-2011, 08:38 AM   #7
Awesome tip, thanks!
TexasSP is offline   Reply With Quote
Old 05-02-2011, 10:26 AM   #8
jwr
I'm glad some of you found the suggestion helpful!
Truer than you know Okay, so it took about 30 seconds on the bandsaw and 90 seconds of pulling the melted plastic off the edges and cleaning them up a bit
Everyone needs a little more orange...
That's a really good idea! I made the first one a little wider but on my current motors I have the motor wires coming off the tabs at 90 degrees so they hit cover. I have new motors coming and I'll solder the wires up a little better so I have more room and can protect the endbells next time.
Old 05-02-2011, 10:47 AM   #9
Trim a little cut out where the wires are then you can solder the wires any way you want!
here is the endbell cap on my CO motor guard\battery mount as example
Old 05-02-2011, 10:59 AM   #10
jwr
Nice!! Good thing I have a few spare pill bottles laying around
Old 05-03-2011, 05:11 AM   #11
Been using the meds bottles for a long while now(In fact I posted this tip in another thread several weeks ago), And I leave the bottoms on the bottle to protect the end bell and brush hood. The one thing I did find is that unless you cut open the vents in motor can, your motors life will be shortened by this method(I know, been there)
So the point is,,, If you run ANY motor skid be sure the motor vents are open and free to circulate air to allow cooling and evacuate metal/copper/carbon particles,,,,,,
The Real Dogman is offline   Reply With Quote
Old 05-03-2011, 09:50 AM   #12
jwr
Dang, I should have known I wouldn't come up with anything original. I was just walking around the house trying to find something the right diameter
Thanks for the tip on the venting!
Old 05-03-2011, 05:18 PM   #13
HAHAHAHAHAHAHA lol
JimmyJam is offline   Reply With Quote
Old 05-05-2011, 09:20 AM   #14
Ditto on the vents for the motors!
pinckbrown is offline   Reply With Quote
Old 05-05-2011, 11:50 AM   #15
i used a really cool plastic with an adhesive backing that you apply with a heat gun works great
murderface is offline   Reply With Quote
Old 05-14-2011, 09:24 AM   #16
good idea, you should stick a novak sticker on them and they would look factory! LMAO
Jake
Jakerz is offline   Reply With Quote
