Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: C.s.r. Bj v4
Old 01-15-2011, 02:44 AM   #1
Default C.s.r. Bj v4
Every project has an beginning:
Following parts I´ve installed:
XR10 Axles
y-town´s BJ V4
VP Knuckles
VP Lockouts
HR Gearbox
HR motor plates
DNA Rims
and some other Parts made by myself...
Let´s take a look:
with best regards from Austria
Gerry
Gerry is offline   Reply With Quote
Old 01-15-2011, 04:58 AM   #2
nice work on the panel !!
can we have a pics of the wheels ??
I'm lookin' for a BWD set
dude26 is offline   Reply With Quote
Old 01-24-2011, 12:10 PM   #3
I wanted to use this day to practice for the next Comp...
But last night it´s snowing .... Well, so I had to do something else at the time going around
I´m even looking for all-round rims and so I made my own wheels... I wanted rims that are right flexible - flexible in terms of width and the offset ...
The wheels are in several sections and consist of following parts:
front and rear ring (Beadlockrings)
2x U-ring - these are the outer rings of the rim , where the tire is threaded middle rings - one ring is 5mm ...
the narrowest rim which I can now assemble measures 10mm and in 5mm increments and then goes upwards
Now i have to take some Vanquish Hex Adapters and then let´s practice!
Greets from Austria,
Gerry
Old 01-24-2011, 02:31 PM   #4
Good work on the wheels...rig too...lookin good!
ittybitty is offline   Reply With Quote
Old 01-24-2011, 02:54 PM   #5
Excellent work! Love them.
limited77 is offline   Reply With Quote
Old 01-24-2011, 10:54 PM   #6
Old 01-25-2011, 01:00 PM   #7
Thank you guys!
Old 01-29-2011, 04:04 PM   #8
There was a slight change of plan, i have made the Hex Adapter myself...
Then i put the rims at the rig- fits great!
And now it´s time to practice a little bit
Best regards from austria,
Gerry
Old 01-29-2011, 04:19 PM   #9
Thats a very nice rig......
DiabloCrawler is offline   Reply With Quote
Old 01-29-2011, 10:03 PM   #10
Those wheels look nice man you got skills.
mint355 is offline   Reply With Quote
Old 01-30-2011, 07:56 AM   #11
nice rig. just to let you know, you will want to ditch the stock upper links. they are way to flexable. i used the 30 degree tube links from axial. much better, no flexing. keep up the great work.
stelerzman is offline   Reply With Quote
Old 01-30-2011, 08:23 AM   #12
Thank you guys!
Yeah, i will made next time the upper Links with 8mm Delrin
Old 01-31-2011, 01:23 PM   #13
Last setup settings:
Weight: 2495g (5,5lbs)
Gerry
Old 05-18-2011, 02:12 PM   #14
It´s a little time ago since i´ve posted the last time But a few little things i´ve changed on my XR10
Chaotic Crawlers Titanium Lower Links
RC4WD Gears
Vanquish motor plates and gear housings
selfmade accu "plattform"
Eric D_Lux Knuckle Weights
and last but not least - some awesome skins from KrawlerKonzepts for the BeetleJuice V4
On friday i drive to Lichtenstein / Balzers to the first SMC Outdoor Comp this year - lets rock the Stones!
Gerry
Old 05-18-2011, 02:15 PM   #15
And another picture of Erics Knuckle Weights:
Old 05-18-2011, 06:15 PM   #16
Still looks great. What is the accu platform?
Harvo is offline   Reply With Quote
Old 05-18-2011, 06:18 PM   #17
Im guessing the battery plates he has made. One on the top of the axle a la Rowdy, and one behind the gearbox.
4xFord is offline   Reply With Quote
Old 05-18-2011, 11:21 PM   #18
Yeah, battery plate is the right word for this what i mean
But the one mounted on the top of the axle is actually not mounted on my xr10, i love the version behind the gearbox/motor
Gerry
