04-04-2011, 06:58 PM | #1 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
| T3rry's Money pit-Ever Evolving-Team Plastic Truck - UGC Viper inspired Custom VP10
I figured it was about time i make a build thread... i have had my XR since they came out, but never gotten around to making a thread, but here it is. My current build: XR10 UGC Viper Chassis - Custom Carbon Fiber cab Vanquish wheels HPI Grabbers Crawler Innovations 2 stage foams Vanquish front Chubs and steering knuckles Custom delrin steering rod Custom high lift delrin lower links Custom delrin upper links All revo/jato rod ends Modified Losi 4" shocks, with gold springs on the front and whites on the rear, limited with fuel tubing Vanquish Transmission cases and bearings RC4WD hardened gears Vanquish motor plates Vanquish Knuckle weights Powered by: Dual MMP Team Brood 35t Motors Hitec 7950 4pl 3s 460MaH Turnigy Nano-tech New things on the way: None, What??!?!??!? Things that have been in my truck but are no longer: Integy v11 35t motors Stock chassis with "the hawk" bodiless topper. Novak M2 Novak 55t motors Traxxas Link RX/TX Dx3e RX/TX Turnigy Servo (lasted about 6 months and then died) Stock stuffs So, on to the pics: Current setup first: here's some updated shots of my truck, i will also add them to the first post, went back to lexan panels, just much lighter than the stainless i was using, i also cut a custom CF cab from 2mm carbon fiber sheet, more curved for easier rollovers, i also rebuilt all of my links from 1/4 delrin sheet, moved the cab back to center a bit more. Drove the crap out of the truck this weekend, got my best finish ever, 2nd place out of 19, i am very happy with that. The panels are "team plastic truck" a dig at the berg guys they started calling our trucks plastic trucks, so we embraced it and took it for our own on to the pics Stainless steel panels, .008 on the sides and .010 on the top and hood, it's a bit heavier than .030 lexan, but i love the look, and the durability should be superb Older pics Previous setups OLD STUFF Originally i did have it normal with a body, but i cant find any pics, i will post them later if i do locate any. Oil Jugs.... Showin off my newly modified Losi Shocks And my freshly bent crazy high lift rear links This is my original bodiless setup, made the panels out of a rubbermaid bucket, simply because that's what i had laying around Last edited by T3rry; 11-28-2011 at 12:16 PM. |
04-04-2011, 07:00 PM | #2 |
Quarry Creeper Join Date: Jan 2011 Location: 801
MMM that is a good lookin rig man nicely done! Looks like you have an impatient crawler with you in the pics, doopid people
04-04-2011, 07:11 PM | #3 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
Nice rig. How do the HPI grabbers work for you guys? I see them being used alot at Teds. |
04-04-2011, 07:49 PM | #4 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
I use the Rovers but the Grabbers are THE tire at Ted. I think the drawbacks that the Grabbers have are filler by the Rovers and vice versa. You give up something to gain others. Terry's rig has been running very well. I believe he is still in the running for our winter points series hosted in Ted's Garage with it in the sportsman class. |
04-04-2011, 07:56 PM | #5 |
I was looking at the Grabbers as a tire to use, but my bossclaws and Sadonas are what is working for me at the moment.
04-04-2011, 07:57 PM | #6 |
04-04-2011, 07:58 PM | #7 | |
04-04-2011, 07:59 PM | #8 |
04-04-2011, 08:13 PM | #9 |
Not quite. I do have a brand new set of them at home, but I'm happier with the Rovers. I haven't tried Sedona's but some guys have. Not for long. We also have one guy that run's everything Losi and the Boss Claws are a part of that. I tried them and for in the Garage, I ditched them. But he still runs them. |
04-04-2011, 08:31 PM | #10 | |
04-04-2011, 09:16 PM | #11 |
Yeah he does. I thought they were Rovers but haven't really looked. They could very well be Sedona's.
04-04-2011, 10:10 PM | #12 |
yeah i honestly don't know either.
04-15-2011, 07:32 AM | #13 |
Installed my Vanquish plates and rc4wd gears yesterday, this thing sounds very beefy now... i have much more confidence in it now... hoping it's borderline indestructible now. i also relocated the battery tot he front axle, not sure if i like that big brick up there, but i can easily move it back. Last edited by T3rry; 04-15-2011 at 07:36 AM. |
05-18-2011, 09:04 AM | #14 |
moved the battery back off the axle, the truck just didn't handle right like that... also got my Vanquish knuckle weights installed, they are a beautiful piece of machining. the tolerances are perfect.
08-28-2011, 10:01 PM | #15 |
well it' evolved/evolving again... there the last shot as the "hawk" topper.... it's on to a VIPER chassis next. |
08-29-2011, 07:22 PM | #16 |
RCC Addict Join Date: Nov 2008 Location: I don't think theres rocks in Florida
Did you get it in white or black?
08-29-2011, 07:34 PM | #17 |
Rock Crawler Join Date: May 2009 Location: Calgary
Rig is looking good and is performing good too Turry. |
08-29-2011, 07:39 PM | #18 |
RCC Addict Join Date: Sep 2006 Location: Depew
08-29-2011, 07:40 PM | #19 |
got the black one, i'll try to get some pics up tonight... i have the body panels off ATM, I was rebuilding the links
08-29-2011, 07:54 PM | #20 |
here are some pics w/o out body... i think i am still gonna limit the front shocks a bit... but i am very happy with how the new links turned out, got lots of travel, very smooth. and stuffed in the bottom of the chassis is my dual MMP, BEC, and receiver |
