06-29-2011, 05:41 PM | #1 |
Newbie Join Date: Feb 2010 Location: Chattanooga
| XR 10 Trans/ Gear Case Cover Up grades?
I know that Vanquish makes a lot of parts for the xr and I know there are a lot of tech articles on the xr, but I want to know what alternatives there are for the trans and gear case cover, axle upgrades, knuckles . I know the Vanquish has milled covers to add larger bearings; Who else makes a similar cover and line of tough upgrades. Comments ? Suggestions? Like I mentioned; I know VP makes this stuff , but I want to know of other manufactures or if some of you guys are milling your own stuff. Thanks Jason |
06-29-2011, 06:20 PM | #2 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
HR and RC4WD make cases for the XR10.
06-29-2011, 06:56 PM | #3 |
Rock Crawler Join Date: Jun 2010 Location: Yelm,WA
All I can say is that Vanquish makes top notch parts, you wont be dissapointed |
06-30-2011, 01:38 AM | #4 |
Newbie Join Date: Feb 2009 Location: Wenatchee
Vanquish! |
06-30-2011, 12:47 PM | #5 |
I like Axial's HD motorplate. It is nice and thick, and has a fully pocketed bearing seat. Rc4wd's bearing upgrade comes with large bearings for both the motor plate and gear case. HR is HR... I don't think a case upgrade is a must. At the very least, run an upgraded motor plate with big bearings & bushings everywhere else in the case. I personally run the Axial HD motor plate & traxxas bushings in stock cases. I do have the rc4wd bearing upgrade, but haven't seen the need to install them yet. |
07-01-2011, 10:05 AM | #6 |
Thanks for the Information.. I like the VP stuff as well. Just thought there might be something "better" or maybe " one off " that someone was making that I could use.
07-01-2011, 10:12 AM | #7 |
07-01-2011, 10:14 PM | #8 |
Quarry Creeper Join Date: Feb 2010 Location: Farmington
Search the forum for XR10 Hop ups and Vendors thread. It has all the info and clicky links you need for the hop ups you want.
07-01-2011, 10:17 PM | #9 |
Here's the link to that thread. http://www.rccrawler.com/forum/showt...95#post3168395 |
07-02-2011, 01:36 AM | #10 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
07-02-2011, 05:56 AM | #11 |
Like I mentioned, If you are going to spend the money... just do it once with VP stuff. I competed with stock stuff for several months. I modified my motor plate for 9mm bearings and the truck worked fine. When I eventually blew a 9mm bearing, I got the heavy duty stuff. Pdog used the VP bushing kit to replace the bearings with the stock cases and plates. He never had any failures. |
