06-30-2011, 07:48 PM | #1 |
Newbie Join Date: Jun 2011 Location: Birmingham
| New to Crawling starting build. comments
I have been researching XR10 for a while now and I have watched every guide I can find. There are so many parts recommendations. Here is a kit with pretty much everything from CKRC http://www.ckrccrawlers.com/ax90017-...ly-p-2637.html I would really just need to sub in a Futaba 4Pks for the twin stick they have listed. Or I can just get the main XR10 kit with: 2 Tekin FXr 45t motor esc kits Futaba 4Pks with receiver Lipo battery Castle BEC Hitech Servo Tires Foam etc. All the other parts like aluminum knuckles, arms etc. Is that required from the start? Thanks, |
06-30-2011, 08:45 PM | #2 |
Rock Crawler Join Date: Oct 2010 Location: Ontario
You could go with a 4PL its about half the price of the 4PKs. I have about 20 packs into mine and a mini comp and the axles are all stock. I say upgrade as you break. |
06-30-2011, 09:14 PM | #3 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
Save dough, get the 4pl You will love it
07-01-2011, 01:52 AM | #4 |
Stock is pretty good, but I have three upgrades that will vastly improve durability. - metal upper links - motor plate upgrade (9mm mod, VP or Axial plates, or RC4WD bearing upgrade) - 5x8x2.5mm non-flanged bushings (TRX3775 one package does both axles) (for top link housing and gear case) **not needed if boing with RC4WD bearing upgrade, but you'll still need 2 bushings (one each for top link housing) |
07-01-2011, 09:48 PM | #5 |
Rock Crawler Join Date: Jun 2010 Location: Yelm,WA
I wouldnt buy the CKRC kit, I think alot of the parts that they are saying are CKRC parts are rebadged HR parts from what I have read on here. I would suggest just buying the kit, building it yourself which will get you familiar with the truck and then buying the upgrades that are neccesary. I believe you can buy the kit for $189 from RPP now, thats a smokin deal. If you look at my build thread I have listed out all the upgrade parts I have added to my truck with prices and where I bought them which will give you an idea as to what you may spend. I will list the parts that I feel are most important upgrades for the XR10; -Vanquish Chubs, Knuckles, Lockouts, Tranny Cases, Motor Plates - Aluminum Wheels (Vanquish or Mayhem Evos are my preferred) -Aluminum or Titanium Links all the way around -RC4WD Gears or Axial Machined Gears - Last edited by BFGcrawler418; 07-01-2011 at 09:52 PM. |
07-01-2011, 10:15 PM | #6 | |
07-01-2011, 11:05 PM | #7 | |
Sure they may have won with plastic parts but some have been modified just like benders knuckles that he stated were modified for zero ackerman. Not everyone has the ability to modify stuff himself or the tools, the parts I suggested are ready right out of the box no modification needed. | |
07-01-2011, 11:15 PM | #8 | |
07-01-2011, 11:21 PM | #9 | |
It's funny that u question why I suggested those parts when u were just hinting in benders build thread that axial should modify their parts, why modify them when other companies like vanquished already have? Re-engineer the engineered? Lmao that's why I suggested them........just saying..... Here's ur comment from his build thread; Last edited by BFGcrawler418; 07-01-2011 at 11:25 PM. | |
07-01-2011, 11:28 PM | #10 | |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
I agree, I personaly wouldn't run a box stock XR10 again, gears and bearing upgrades are required for the XR10, like others have said skip the 4pk and get the 4pl (you will be just as happy) and take care of the bearing/gear problem with the saved money also take into consideration CKRC's rep, type CKRC into the search and read some reviews on their service... or should I say lack of Last edited by fred0000; 07-01-2011 at 11:31 PM. | |
07-01-2011, 11:32 PM | #11 | |
I personal have had great luck with ckrc and have nothing bad to Say about them but buy with caution cause lots of bad reviews from others. Last edited by BFGcrawler418; 07-01-2011 at 11:34 PM. | |
07-01-2011, 11:45 PM | #12 | |
