08-11-2011, 06:09 PM | #1 |
Rock Crawler Join Date: Jan 2011 Location: Hartford City, Indiana
| TJ Steve's Progress chassis/Chaotic linked build adventure. I finally got to the place where I needed to start this thread. I was gonna start it 2 weeks ago but got sidetracked by the design bug. More on that later. Anyhow, as soon as I saw Hardknockz Progress build, I knew this was the way I wanted to go. I had my XR10 box under the workbench waiting for me to finish my scaler, but that didn't last long.......... (It's still not finished) I got the Progress chassis in the mail and started trying to figure what I was going to do with it. I decided that I really wanted Titanium links but nobody was making them for this chassis. So I ordered some Delrin tube and 4mm all thread from McMaster Carr, and was going to go with that. The more I thought about it, I didn't want fat links because I thought it would undermine the extra belly clearance of the Progress. So I went ahead and ordered a set of XR10 links from Chaotic. I kinda thought that they might work, because the two builds with this chassis that I knew of, had used axial XR10 links. I figured if they didn't, I could just bend them to make them work. I had already contacted them about some for the Progress but they said it wasn't happening yet. After I placed my order, Nick contacted me, and one thing led to another and Marc said they would send me two sets to try if I would be willing to get all the info they needed. So, after about two weeks, I ended up being the first guy with Chaotic Crawlers Titanium Links for a Progress Chassis! These guys are a first class operation, with a passion for RC Crawlers, and put out some quality products! I've not ever worked with anyone better, period! A great big THANKS for all their help! You won't go wrong dealing with these guys. |
08-11-2011, 06:21 PM | #2 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
im watchin this one cause your close to home an i mite have to get with u an see this
08-11-2011, 06:26 PM | #3 |
| Here's the list.............. Axial XR10 kit RCP Crawlers-Progress Chassis Chaotic Crawlers-Titanium Links and Tie Rod Traxxas-Revo Link Ends Pit Bull-Rock Beast Tires Dos Piezas-Foams VP-SLW V1 Wheels VP-Steering Knuckles VP-Chubs VP-Lockouts Hitec-HS-7950TH Servo HH-Torquemaster Pro 40T Motors CC-BEC Tekin-FX-R ESC Spektrum SR3520 Receiver Heyok (Al Jackson)- DIG Probably forgot something else, but can add later. I forgot the Losi gold shock springs. I'll most likely go with the 4" Losi Crawler shocks too. Rowdy Racing-Battery mount I've either have, or it's on the way, everything except for the servo, motors, ESC, receiver, and dig. I'm not rich, so I have to buy a little at a time. Last edited by TJ Steve; 08-28-2011 at 07:10 PM. |
08-11-2011, 06:29 PM | #4 |
i have everthing u need if u get that far befor u get it all
08-11-2011, 06:32 PM | #5 |
08-11-2011, 06:37 PM | #6 |
ive been lookin at that chasis myself along with 3 others an no one around here runs them so it will be cool to maybe come see this one in person
08-11-2011, 06:37 PM | #7 |
Where's the pics?
08-11-2011, 06:40 PM | #8 | |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
I'm assuming you're running a DX3E or something by the rx you listed. You may wanna think hard about running a 4PL & dual ESC's. Makes a HUGE difference in what can be done with this rig. I know it's a pricey way to go but something to think about if you're going to comp your rig. Keep us posted on your build & hit me up if ya run into any snags. J.D. | |
08-11-2011, 06:46 PM | #9 |
| I read everything I could about the XR10's, and decided to go with the 10mm mod on the motor plates I had read about in Ittybitty's build. I did figure out how to clearance the bearing flange for the flat head screw. Some of you might be interested in this, so I took a pic. I put the bearing in my bench vise, (I've got some brass liners) clamped it just enough to hold while I filed a notch in the flange with a chainsaw file. They have a fine cut,and are made to file hard material. Then I used that Locktite retaining compound in the pic to hold all the bearings in the plate. Last edited by TJ Steve; 08-12-2011 at 05:14 AM. |
08-11-2011, 06:54 PM | #10 |
08-11-2011, 07:03 PM | #11 | |
Yeah, I've got a DX3R I just bought back in February when I only thought I would be running a scaler. Little did I know then, how much fun this actually is. It looks like I'm stuck with the Spektrum for a while. I've got to drive at least 70 miles for any comps around here, so the Spektrum will be great to learn on. Thanks for the offer for help, I may have to ask a few question before this thing is finished. I'm glad you saw this as I think you will be real interested in where this build is going. Meanwhile, I got a little more story to tell, before I post a pic of where this thing is at now. | |
08-11-2011, 07:10 PM | #12 |
Rock Crawler Join Date: Sep 2009 Location: dartmouth ns
With the 10mm mod (which i did also) you will have to space the motor out with small washers between the motor and plate. |
08-11-2011, 07:13 PM | #13 |
| Here's the pics. I'll try to explain as I go along without getting too long winded. Here's the pics with the first set of links. I wasn't sure what to think at this point, this being my first crawler. |
08-11-2011, 07:13 PM | #14 |
I wanna be Dave Join Date: Oct 2007 Location: 801
We have been looking forward to seeing this build for a while now!" We are excited to see you finish it up and drive it. And we can't thank you enough for all your help and patience on getting these links correct. Everybody is in for a treat with this build! |
08-11-2011, 07:21 PM | #15 | |
Rock Crawler Join Date: Mar 2004 Location: Albany
08-11-2011, 07:22 PM | #16 |
| Link set number 2. You can see that the rear links are too long on this set, so back to the first ones. |
08-11-2011, 07:26 PM | #17 | |
08-11-2011, 07:47 PM | #18 |
| I think it was at about this point that I decided to build a jig to more accurately measure my wheelbase. I was using a steel rule and a pair of good digital callipers, but not able to come up with any consistancy. This is what I came up with. It took several hours one evening, but was well worth the effort as it made measurements from hear on out a breeze! After many emails back and forth with Marc and Nick, many adjustments (shock mounts, frame link points, link ends), we came up with a very good set-up. Oh, I almost forgot, I limited my shocks internally with some 6mm spacers. |
08-11-2011, 08:04 PM | #19 |
| Here's the final pics of what it looked like at this point. I'll let the pics speek for themselves. Well It's my bed time here in Indiana. 10:00pm, and I have to get up at 4:50. Here's a little teaser to keep you all interested. Let's just say I got jealous of Marcs Especial Bodiless, and got out the drawing board! The "Old School Bantam" To be continued with more pics tomorrow................. Goodnight Ladies and Gents. |
08-11-2011, 08:33 PM | #20 |
First off...you got some hairy hands dude. Second...You said the 2nd set of links were too long but didn't specify why. Was it just the lowers, just the uppers or all 4? Was it because it threw your wheelbase out past 12.5" or just clocked your axles all silly like? Third...I noticed that you have your shock arms on the OUTSIDE of your chassis. You MAY wanna try em on the inside of the plates. Obviously it's up to you but it really triangulates the suspension & once you find that happy spot for your setup, weight & driving style...the rig is just flat planted. Again...up to you. There are a few guys that run em outboarded but after trying both setups...I found my rig to be way more stable. Fourth...got any wheels so you can shoot some GC pics & numbers? Aaaand fifth...You got some hairy hands dude. Seriously...good looking build so far. I've kicked around a topper design or 2 myself for the PROGRESS but I don't wanna throw anymore weight up top than I need to. Plus...I like painting my lids. |
