08-16-2011, 05:53 PM | #1 |
Pebble Pounder Join Date: Jan 2011 Location: vienna
| XR10 with VIPER chasis - upper links help
I'm having a hard time looking for a upper links that will fit the VIPER. What upper links are the VIPER driver using and which rod ends? Thanks |
08-16-2011, 06:00 PM | #2 |
There are TONS of Viper builds. Do some searching and you'll find the answers faster than waiting on people to do the work for you.
08-16-2011, 06:09 PM | #3 |
Rock Crawler Join Date: Jan 2011 Location: New Brunswick
| ***Chaotic Crawlers Titanium XR10 links (simple how to)*** This is all I got brotha. Look up Articzap, Tydl, DickyT's old build, jeepkid has awesome ideas too. This just scratches the surface, I didn't meen to leave anyone out, just list off a handful of Viper builds off the top of my head. |
08-16-2011, 06:10 PM | #4 |
Harley with all due respect I did look and there's info that are confusing. And you're right there's alot of build out there, that I saw. I guess I should state that when I post. Ok let me be more specific. CrawlHer posted a upper links for the VIPER using the Vanquish Product Wraith Titanium Upper Link Arms http://www.vanquishproducts.com/wrai...per-links.html Anyone else try this out? |
08-16-2011, 06:26 PM | #5 |
I hadn't even heard of that one yet... I don't have a Wraith, but I know that they have a 13.5" wheelbase. I can't say if the links would work out or not. One good trick is to use some 8-32 all thread rod and try out some different combos. It's easy to bend and cut, and Revo ends fit perfectly onto it.
08-16-2011, 07:12 PM | #6 | |
RCC Addict Join Date: Nov 2008 Location: I don't think theres rocks in Florida
I can measure mine for you, but it all depends on where you want to clock the axle. I for instance have the gearbox very level, where jeepkid has his clocked to the sky. lol And there isn't a right or wrong, but what works for me, may not be to your liking. The all thread is what you should do, you could even get some stainless steel tube and be done with it. Use Revo rodend tra5347. The uppers front and rear only worked for me with a bend for clearance. | |
08-16-2011, 07:20 PM | #7 |
yeah from what I've been searching in this forumn there is no one solution that you can "just buy and install" out there Awhile back I pm Jeepkid about it and he help out, ended up with using the axial bent pipe not to thrill about it so thats why I'm looking into something else i might do the solution eisman and Tydl mention in this post worth a shot, cheap and flexible solution thanks guys Last edited by bikeboy; 08-16-2011 at 07:29 PM. |
08-16-2011, 07:38 PM | #8 | |
RCC Addict Join Date: Sep 2006 Location: Depew
From my build thread. Quote:
08-16-2011, 07:42 PM | #9 |
08-16-2011, 07:46 PM | #10 |
| Inboard ducks the links in and keeps them out of the way. I did it for the reason of running those Traxxas links. Out board would push the axle way to far down. Slight less stability, but plenty enough to keep the truck planted. Most guys are running front and back inboarded, I am only running back inboarded right now.
08-16-2011, 07:47 PM | #11 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
I have now clocked my front down a good bit. Running CI lower clearence links in the front now. My servo is close to level.
08-16-2011, 07:49 PM | #12 |
| Forgot about that, mine are inboarded too, but I did them originally outboarded. I definitely makes it easier to clearance the shocks by inboarding, but you do get some axle sway.
08-16-2011, 07:50 PM | #13 |
08-16-2011, 07:51 PM | #14 |
08-16-2011, 07:53 PM | #15 |
08-16-2011, 08:00 PM | #16 |
08-16-2011, 08:04 PM | #17 |
Thanks Articzap The second picture shows a great perspective. |
08-16-2011, 08:10 PM | #18 |
FWIW, I found that when mocking up my upper links, when they were outboarded there was tons of binding. None with them inboarded. An attribute of the straight links I suppose.
08-16-2011, 08:17 PM | #19 |
Best answer of the day. The simplest solution to find what works for you is to pick up some all thread and revo ends. then mount the rod ends to the axle and chassis. postiion the axle to the desired clock position and measure the distance between the ends of the rod ends. Then add 20mm to that measurement (to account for 10mm of threading on each end) This will get you to where you want, and you can later find apporiate links to suit your needs (such as the Lunsford Rock Grinders that come in virtually any length you could need. Plus you could always sleeve the all thread with some brake line, and bend the rod for motor clearance, ec. |
08-16-2011, 09:05 PM | #20 | |
Me... I just did the math, and got links to suit my needs. It is the best advise though. | |
