09-25-2011, 12:44 PM | #1 |
I wanna be Dave Join Date: Jul 2008 Location: Southwestern, Ohio
| Bearing problem...looking for solution
I am running the Axial hardened, lightweight gears and titanium shafts with Vanquish cases, plates, & upper link mounts. The problem I am having is with the bearing (5x8x2.5mm) on the end of the drive gear/idler gear shaft. I have exploded two of those bearings so far and have no idea what is causing it. Anyone have any clues? Thanks!
09-25-2011, 12:59 PM | #2 |
RCC Addict Join Date: May 2009 Location: In the warmth!
Those little bearings stink, to say the least. I replaced all the 5x8 bearings with the Traxxas bushings. They are holding up real well |
09-25-2011, 01:37 PM | #3 |
I thought about a bushing. Do you know what yu used?
09-25-2011, 01:41 PM | #4 |
My buddy runs the TRX bushings on the end of the shafts, and breaks them everytime we go crawling! He even dremmeled out the plastic to fit 2 trx bushings in there, and broke both of them yesterday! Crazy $hit! I got the VP upper axle cases so I could eliminate those tiny bearings/bushings. Last edited by ROWDY RACING; 09-25-2011 at 01:43 PM. |
09-25-2011, 01:54 PM | #5 | |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
09-25-2011, 01:58 PM | #6 |
09-25-2011, 02:00 PM | #7 |
09-25-2011, 02:57 PM | #8 |
Rock Crawler Join Date: May 2007 Location: Prescott
Check to make sure the shaft is not bent also. That can lead to premature bearing failure. It happened on my front axle and I run bushings to replace the outer bearings since they would die often.
09-25-2011, 04:13 PM | #9 |
The part number for the traxxas bushing is TRX3775
09-25-2011, 05:38 PM | #10 |
Checked the shaft, it is ok, as I expected it is fairly a fairly new titanium one. I will give the bushing a shot and see what happens. I cannot see spending the change on the Pricey VP Axle Housings, especialy since I am currently in the middle of a Wraith/TTC build and getting ready to start an FOFF build. Thanks to every that replied! |
