Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: what tires on xr10
Old 11-09-2011, 11:53 PM   #1
Default what tires on xr10
just order the xr10 and need to get the tires just want to know what you guys are running i need to set it up now
1976drew is offline   Reply With Quote
Old 11-10-2011, 01:14 AM   #2
its out of 3 hb rovers hb sedonas or losi boss claws its like what car you like differnt people different opinion but if you stick to one of these three you cant go wrong
RockMafia is offline   Reply With Quote
Old 11-10-2011, 02:20 AM   #3
don't forget CrawlerInnovation foam
dude26 is offline   Reply With Quote
Old 11-10-2011, 03:51 AM   #4
It also depends on the type of rock, we crawl smooth slatelike rock and the boss claws are useless not a patch on rovers. I've got a set of white dot sedonas to try on Sunday, I have high hopes.
posted via tapatalk
ManxCrawler is offline   Reply With Quote
Old 11-10-2011, 05:35 AM   #5
donas front boss claws rears ci foams
slowride1 is offline   Reply With Quote
Old 11-10-2011, 09:22 AM   #6
I have been useing HB Rovers for 9 months now, never hand any less traction then any other tires, but will be trying some boss claws this weekend.
dabbill is offline   Reply With Quote
Old 11-10-2011, 12:37 PM   #7
I've been trying to decided between both. This just might be the ticket.
Thx,
-NB- is offline   Reply With Quote
Old 11-10-2011, 04:00 PM   #8
so non of the pro line are good
Old 11-10-2011, 09:33 PM   #9
really all depends on what you are crawling on . all the tire that have been stated above all work really well about any where
Old 11-10-2011, 09:44 PM   #10
We have a massive amount of traction down here in Florida, Cape rock, Used Concrete. Most of us run HB Sadonas in the front and HB Rovers in the rear.
They really hook up. Good luck..
stelerzman is offline   Reply With Quote
Old 11-10-2011, 10:09 PM   #11
Pro-Line Chisels work pretty good but are kinda unpredictable on some types of rock. I havent tried it yet, but 2.2 super swampers may do ok too. Over all I run HB Sedonas or Rovers....I have also been using a super cut up set of rovers that are pretty much pin tires, XJ Farmer named em B-rovers.
BLKXJ 96 is offline   Reply With Quote
Old 11-10-2011, 11:24 PM   #12
chisels work well but not for the price. they absolutely will not perform in wet conditions compared to other tires.
if you are always in a dry climate when you run and rarely get rain, you may have the most success with them, however, i agree with the previous posts on tire choices. i have run..
chisels g8
rovers white and blue
xlocks
comp claws
have not used boss claws but i don't think they would work as well in my area. you can watch youtube vids of different people running and determine for yourself what you think works well.
i love my white dot rovers. my buddy runs whites in front and blue in the rear, and it helps it to not get caught up as much. i'm not quite convinced to do that.
consider what foams also. CI foams are legit. i need to order some for the rear.
pitcher2103 is offline   Reply With Quote
Old 11-11-2011, 06:46 AM   #13
That is the combo I chose.
Have been using it for almost 2 years now and have had very good luck.
The guys in Missouri nicknamed it the mullet combo.. Business in the front, party in the back...
I really want to try the Sedona / Pin Tire cut-n-shuts that Crawler innovations is putting together.
For the $$ I think a set of white dot Sedonas and CI foams would be the way to go.
If you go to the Crawler Innovations site, just order it all from them.
Those guys won't turn you wrong. And if you tell them your running conditions and weight of rig, etc, they will help dial you in on foam set up.
bigstu is offline   Reply With Quote
