Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: She's all done !!
Old 12-08-2011, 11:41 PM   #1
Default She's all done !!
Thanks for all you guys help. Still need a servo horn.
Tried to do a tidy wiring job using cable sheathing. Turned out pretty well.
Pics not as clear as I'd like but they are what they are.
mostly stock:
xr10 kit
hobbico c-170 servo
fxr esc
cc bec
2 - holmes hobbies 35t expert machine wound motors
14t pinion in front - 13t on rear
tried 9mm mod on front - did not feel good about it - went axial hard anodized
motor plate with 9mm bearings
stock rear motor plate with avid bearings
no dig (may go to a second fxr later)
rovers
turnigy 1300 45c batteries
mounted front shocks inboard
removed battery tray - using electronics plate
gt-3b tx/rx (unhacked - so far)
at the time i took these pics - connectors not on the esc.
took her out tonight in the street to climb some curbs. late and dark.
come on giver her a test. climbed curbs like butta.
give a little trail run tomorrow. gotta get the servo horn before
bbking9 is offline   Reply With Quote
Old 12-09-2011, 08:36 AM   #2
Jealous... I'm just a kit full o pieces so far
why diff pinions?
Mysterious is offline   Reply With Quote
Old 12-09-2011, 08:43 AM   #3
why diff pinions?
I did the same in mine. More pull less push.
chopperray is offline   Reply With Quote
Old 12-09-2011, 08:48 AM   #4
Custom Carbon Fiber
Robbob's Avatar
why diff pinions?
Help battle Clod Stall ........... Front spins faster then rear. Some like having it some prefer not to have it.
Robbob is offline   Reply With Quote
Old 12-09-2011, 09:21 AM   #5
the funniest thing I found so far is - running in the street over curbs etc... last night. the front wheels are weighted and have so much grip on the concrete - when you turn it sounds like you have a flat tire.
Old 12-09-2011, 02:03 PM   #6
looks good! you should be pretty set. Also get that gt3b hacked! lol
Krawler23 is offline   Reply With Quote
Old 12-09-2011, 02:10 PM   #7
Hey Frank. You read my mind. I was thinking of getting the hack.
Ran it first time today on some gnarly rocks by the house.
It did exceptionally well - except if I got in a bind the rear gears would click/pop.
gotta look into that.
All in all - for $430 - it is AWESOME machine.
Thinking about a Wraith as well - but that kit is $300 compared to $130 - $140 for the XR10.
When is all your stuff arriving?
Old 12-09-2011, 02:18 PM   #8
Looks great, and all for $430? Wow, you did good.
I really dig the paint.
OKJeepin is offline   Reply With Quote
Old 12-09-2011, 03:04 PM   #9
Nice job man! Can I ask where did you find that braided wire loom that you have over your motor wires? I've been looking for some to put on mine. Love that paint job also!
DiggyStyle is offline   Reply With Quote
Old 12-09-2011, 03:20 PM   #10
Well - while I used to be able to paint (haven't in a long time) - I could never paint like that. It is actually more orange - but looks reddish in the pics.
It is a VERY thick vinyl sticker set from a company called Freq-E skinz. It is regular $35 -someone had it for $17 on sale.
The cable sheathing came from cableorganizers.com - cheap and you can buy it buy the foot. I think I spent $3.00. Be sure to get the non-fray one.
I got 1/8" and 1/4". Just what I needed. It stretches out pretty good. I think it looks awesome cause you cant see thru it like others. here is the link.
Non-Fray Expandable Braided Sleeving – Just Cut With Scissors
For some reason - pricing is not coming up - but it is $0.55 per foot. I got 3 ft of each. Cheap, fast shipping as well.
$430 - I tried to do it on a budget. Servo, ESC, CCBEC were all used and cheap. Already had radio, charger. Ended up not being able to use my existing
lipos - so $22 more than expected on 2 - Turnigy nano-tech 3s 1300 mah 45c lipos. Big splurge was getting the Axial Hard anodized motor plate. While I thought I did an OK job on doing the 9mm mod. It just didnt seem right when I put it all together.
Old 12-09-2011, 04:37 PM   #11
I just have a couple things left to order and then i'll get her ready! I am pretty excited about it. I was also considering the wraith as well. It looks like a lot of fun.
Old 12-09-2011, 04:39 PM   #12
Great start so far, the motor plates should help with gear failure.
DRCrawlGood is offline   Reply With Quote
Old 12-09-2011, 06:30 PM   #13
Get a dig or a second ESC and you'll see how much better it goes. Trust me.
Also, the gears are the achilles heel of the XR10. I have only gone through two gears in the year I have had mine, but I don't use it as much as other and try to go softer. Do some research if you chew through gears and you'll find some good upgrades.
Mides is offline   Reply With Quote
Old 12-09-2011, 06:50 PM   #14
Did you say all done.......... never I say never.
Looks good. Go for that 2nd esc though if you have not already , it will bring out the beast in this unit. Also if you haven't yet go run a few comps with it. They will make you better.
BUGGYBOY is offline   Reply With Quote
Old 12-09-2011, 07:15 PM   #15
yea - I said "all done" - yea right ...
Old 12-09-2011, 08:03 PM   #16
Looks good!!! The mods to the Xr can go on forever....Run it stock and do minor changes.....pretty soon you will have a good running rig....
BLKXJ 96 is offline   Reply With Quote
Old 12-09-2011, 08:55 PM   #17
Yea - im not replacing anything till it breaks.
Old 12-09-2011, 09:00 PM   #18
looks great an yes drive it till it breaks an have fun an lurn the truck
slowride1 is offline   Reply With Quote
Old 12-10-2011, 11:57 AM   #19
Get a Robitronics aluminum servo horn. Best one on the market!
Old 12-10-2011, 01:05 PM   #20
Awesome cheap build!!! I noticed that you made the same mistake as me. The chassis is backwards. The long skinny hole in the chassis should be to the back. I ran mine for awhile that way and it didn't really seem to make much of a difference switching it around but I did switch it. Have fun absolutely love mine!!!
mammoth is offline   Reply With Quote
